Old 01-13-2018, 04:51 PM   #1
Will heat pump turn on furnace
We have a 2017 sunseeker 2800qs and are wondering if we have the heat pump on and the outside temp drops below 32 degrees, Wil the heat pump automatically turn on the furnace when the heat pump can not heat efficiently?
Tom C 47 is offline   Reply With Quote
Old 01-13-2018, 05:01 PM   #2
cavie's Avatar
NO. The furnace is controlled by the thermostat temp setting, not the heat pump. IF the heat pump has an aux heat strip ( I do not know if they do, I doubt it due to a large amp draw.) then the heat pump will turn that on. Its just like the heat pump in a residence.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-13-2018, 05:35 PM   #3
Hoglou's Avatar
well maybe
Our heat pump will kick on the propane furnace when the heat pump fails to extract external heat from the air. Or we can select furnace only. We did dump the dometic heat pump for a coleman unit last year. I do not think the dometic had that feature.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-13-2018, 05:50 PM   #4
If it works like one in a house. Then it has heat strips when it get below a certain temp out side the heat strips kick in and provide extra heat. The blower on the furnace will cut on to circulate the heat.
Gonefishing1 is offline   Reply With Quote
Old 01-13-2018, 05:50 PM   #5
cavie's Avatar
see there, never to old to learn something.
Old 01-13-2018, 05:55 PM   #6
cavie's Avatar
If the furnace blower is on, the furnace is providing the heat. It's not gonna just move the heat around.
Old 01-13-2018, 06:38 PM   #7
Hoglou's Avatar
As a side note it is 28 right now outside. Using an oil radiator in the coach, keeping up to 72. Bet I would burn a lb or two of propane this weekend if I was using the furnace........
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 01-13-2018, 06:59 PM   #8
That is correct but it is the heat strips that are proving the extra heat. If like a house furnace.
Old 01-13-2018, 08:58 PM   #9
On our 2017 2860ds no it wont bring in the furnace, when we camp in the winter we find that we can get away with using the heat pump during the day but have to switch it over to furnace at night when the tempature drops
gasgastwo is offline   Reply With Quote
Old 01-14-2018, 07:44 AM   #10
mcnabbwr's Avatar
It appears there are a lot of different types of answers. Looks like it would depend on your particular unit. Our unit has the electric heat tape contained within and it will also activate the furnace if needed.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
furnace, pump
