Old 10-30-2014, 09:42 PM   #1
Wimpy bench seats
Noticing that the dinette seats are supported by the thinnest of thin paneling. Has anyone tried to beef them up a bit?
What is their rated capacity?
2010 Sunseeker 3170DS
timjneu is offline   Reply With Quote
Old 10-31-2014, 08:31 AM   #2
GM
bclemens's Avatar
We've been running those in rental fleets for years with no issues (unless you're jumping down from the bunk...which is why we put a ladder there).
The paneling is supported by cross members and the cushion itself distributes the weight. Unless you're climbing on it without the cushion, we have had 4 guys sitting there, all over 200lbs. I don't know that we have ever rated them...but you can easily add another layer if you're concerned.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 10-31-2014, 01:13 PM   #3
blythepyrate's Avatar
I just removed and deconstructed one of the dinette bench seats in my 2009 2900 and once you see how it is constructed on the inside (presuming yours is similar - which I expect it is) you understand how the weight is distributed. Those side panels aren't supporting weight, there are heavier wood supports underneath the thin plywood overlay.
While I wasn't impressed with the attention to detail on my particular bench's construction, (inferior wood, screws not straight, bent brackets) I think the design is solid to support a LOT of weight.
Hope this helps!
Pyrate
Fuzzy Bear (Newf) & Emmett (ginger cat)
2009 Sunseeker 2900 & Jeep Cherokee Sport
blythepyrate is offline   Reply With Quote
Old 10-31-2014, 06:10 PM   #4
I guess we will leave it alone and see how it does.
Thanks!
