Old 08-21-2016, 08:02 PM   #1
Window screen
Iam looking for anyone that can give me any info on finding parts for my 1999 class c sunseeker 280 model. In particular a window screen on the right side window.Thank you.
rracer56 is offline   Reply With Quote
Old 08-21-2016, 11:47 PM   #2
If you have the frame you could replace the screening material which is available at all hardware stores.
If you don't have the frame you could probably also buy the frame sections at the hardware store. I recently saw what looked like my window screen frames in Home Depot.
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 08-22-2016, 10:40 AM   #3
I have checked every place u can imagine even some salvage yards . The problem is its not completely squart there are 2 corners rounded on it.anyour other help.
Old 08-22-2016, 10:50 AM   #4
I saw the rounded corners at Home Depot in the screen door section.
Old 08-22-2016, 10:52 AM   #5
Ok thanks I will check again.They told me that they didn't have the size I need and couldn't even order it.
Old 08-22-2016, 10:54 AM   #6
It's not the screek door it's the window above the sofa on the side passenger.
Old 08-22-2016, 10:59 AM   #7
The frames I am talking about you assemble yourself. You can make a custom size. All you need is four straight sections and the corner sections. You can cut the straight sections to your desired length. I think I used a hack saw.
I did this for screen doors at home using the square corners. I was surprised to see the curved corners in stock and in black!
Old 08-22-2016, 11:00 AM   #8
It shouldn't matter.
Old 08-22-2016, 11:00 AM   #9
Like I said I will check again thanks for your help by chance do u know where I can get other parts .
Old 08-22-2016, 11:07 AM   #10
No but There was a thread this summer that had links for window parts. I recall a dog jumping out a window and causing damage to the mechanism.
