Old 10-30-2014, 03:34 PM   #1
Winter using rv
First, I'm not looking for anyone's opinion on whether or not to do it this way. I've used the fresh water tank for a couple of years with my Sunseeker and haven't had any problems doing it this way, till today.
I usually put 2 gallons of antifreeze in the fresh water tank. Empty the hot water heater, then bypass it. Turn on the pump and run it through all faucets and toilet. Today I do it the same way and it doesn't run through. I can hear a slight hum of the pump, but its like there's no antifreeze to pump in. I'm level and in the same spot I winterized it the other years. The really strange part is I turned the knob for the fresh water tank to see if it would come out and it didn't. I found another thread where someone put 9 gallons in and be had the same problem. I know the knob is in the correct position, before anyone asks that.
I was going to go out and get a couple more gallons tonight, but after reading about the guy with 9 gallons and still nothing I thought I would check here first for ideas. By the way, in the thread I found there were no answers, but other people with the same experience. Kind of leaves me scratching my head especially since I've done it this way for several years.
Brian217 is offline   Reply With Quote
Old 10-30-2014, 03:47 PM   #2
TURBS's Avatar
I know this isn't your answer but I'd put a winterizing kit on it so you don't have to put it in the fw tank.
$20.00 at most camping centers.
BTW I bet 2 gallons isn't enough.
Turbs
Old 10-30-2014, 03:50 PM   #3
I probably will install a kit at some point, but just can't figure out why it's worked for years and now it doesn't.
Old 10-30-2014, 03:59 PM   #4
TURBS's Avatar
If the pump was working recently I'd suspect not enough antifreeze to be picked up in the tank.
Albeit possible the pump is bad?
Tank could have sagged some?
Turbs
Old 10-30-2014, 04:03 PM   #5
I did use the fresh water tank over Labor Day, but I guess it could have gone bad. It has a quiet, constant hum even when faucets are closed. When I open a faucet I don't hear the loud noise I usually hear, but, there is a difference when I have the pump on and off. I get a gurgling from the faucet when its on.
Old 10-30-2014, 04:06 PM   #6
Oakman's Avatar
Since youíve done it this way before without issue then my guess would be that either the fresh water tank has shifted or the pickup line within the tank has shifted.
Also check to make sure the pickup line on the pump from the fresh water tank is tight. A slightly loose connection allows the pump to suck air instead of fluids.
Iím not familiar with how the fresh water tanks are installed in Sunseekers but Iím amazed you were able to winterize with just two gallons in the fresh water tank.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 10-30-2014, 04:06 PM   #7
Average Joe
MrJoe's Avatar
Do you see pink in the filter housing? Mine did that when I left the tank drain open....
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 10-30-2014, 04:08 PM   #8
TURBS's Avatar
Me to!
My sabre takes 4 minimum!
Turbs
Old 10-30-2014, 04:14 PM   #9
I'm going to pick up a couple more gallons tonight. Maybe something did shift. I hate when something that normally takes 10 minutes takes up a lot of the afternoon!
Old 10-30-2014, 04:28 PM   #10
Cut your losses(2gals antifreeze) top the fresh water tank with water and see what happens. If it pumps, I suspect either the feed line was not covered for some reason, or your pump didn't have enough antifreeze volume to start the draw cycle.
Switch to a bypass kit and go that route the remainder of your time with the unit.
winter
