Old 11-16-2017, 07:19 PM   #1
winterization 2012 sunseeker
i am having a problem getting the pump getting the pump to suction the antifreeze from a one gallon jug through a bypass valve.
Rick50 is offline   Reply With Quote
Old 11-18-2017, 09:54 AM   #2
SeaDog's Avatar
check to ensure the valves are aligned properly I had problems until I realized I had my postponed wrong this year.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-18-2017, 10:51 AM   #3
PPST Wannabe
kenandterry's Avatar
Like others....
We’re assuming your pump works to use the on board water supply okay? If not, you’ve got a pump problem.
Just make sure you’ve got the valve turned correctly to source the antifreeze from the line you’re putting into the jug.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
2012, sunseeker, winter
