Old 11-11-2018, 06:51 PM   #1
Winterizing 2019 3010ds
Hello
I just purchased a 2019 forest river sunseeker 3010ds. We are winterizing the unit and i was wondering if there was a low point drain and a water heater bypass for the unit? And if so where would they be located?
Michael
2019 Sunseeker 3010ds
SunseekerFAMof6 is offline   Reply With Quote
Old 11-11-2018, 07:26 PM   #2
Low point hot and cold behind passager side dullys . Water heater bypass valves under kitchen sink cabinet , front panel with 4 screws on cabinets fronts will get you to them .
fred+sherry is offline   Reply With Quote
Old 11-11-2018, 07:30 PM   #3
Thank you so much for the help!
Michael
Old 11-11-2018, 07:41 PM   #4
Bill and Gail's Avatar
The one low point drain has a cap (whatever you do, don't lose the special washer), the other has a valve, in by the water pump, filter area.
Bill and Gail is offline   Reply With Quote
Old 11-11-2018, 07:53 PM   #5
Thank you!
Old 11-12-2018, 09:11 AM   #6
I found the low point drains. Only the red pipe had a threaded cap the blue did not. Is this normal? Thanks in advance Click image for larger version
Old 11-12-2018, 10:48 AM   #7
Shredder's Avatar
Yes that is normal. You unscrew the cap to drain the hot. For the cold you open the compartment where your water filter is you will see a vale. That one is for your cold water.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 11-12-2018, 07:47 PM   #8
It will also drain fresh water tank . With the valve open . You picked a great floor plan . We enjoy ours
Old 11-12-2018, 07:52 PM   #9
Don't forget to remove the water filter.
Old 11-12-2018, 07:55 PM   #10
Thanks everyone for your responses. I appreciate it being a newbie!
winter
