Old 02-24-2019, 05:26 PM   #1
Winterizing 3010ds
Hello
I just returned (to NY) from a trip to Florida. Started to winterize the unit again. Drained low point, emptied water heater, set the bypass for the water heater, removed the filter, got the hose to pump the antifreeze through the system, turned on the water pump and it went on but no suction. I tried everything. I missing something? Any help is appreciated. (When I winterized it in November all worked well with no issues including pumping antifreeze through system using water pump)
Michael
2019 Sunseeker 3010ds
SunseekerFAMof6 is offline   Reply With Quote
Old 02-25-2019, 09:43 AM   #2
Shredder's Avatar
I know your trying to winterize you unit but have you tried putting some water in your holding tank and seeing if the pump cycles that water??
Any holes in the pickup hose from the antifreeze may cause issues too..
I all else fails i would suggest you blow all of the lines out with the air connection. and winterize that way. I know its a little more tedious however better to be safe them sorry.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 02-25-2019, 09:48 AM   #3
Thanks shredder. I ended up blowing the lines out then dumping antifreeze down all the drains and traps and down the toilet.
Appreciate your response!
winter
