Old 12-29-2012, 02:29 PM   #1
Smilinggrammy's Avatar
winterizing
Should we take off the water filter or just blow antifreeze in it will pumping through system
Smilinggrammy is offline   Reply With Quote
Old 12-29-2012, 04:07 PM   #2
Remove the cartridge from filter housing and replace the empty housing. The housing will fill with Anti-freeze before it flows through the rest of the system.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 12-29-2012, 04:13 PM   #3
PPST Wannabe
kenandterry's Avatar
Some people insert an empty water bottle that fits inside the water filter chamber, just to reduce the amount of anti-freeze to fill the chamber. If not, install a screw on replacement where the chamber would be installed to reduce anti-freeze volume also.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 12-29-2012, 04:34 PM   #4
3 Happy Campers's Avatar
Last year I started using small party balloons to fill the space in the filter housing.
Bought a pack of 20 for $1 @ of course the dollar store.
At one a year they’ll probably dry rot before I get to use them all.
Just blow one up tie it off & shove it in. Run your pink stuff & then pop it when done.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 12-29-2012, 05:08 PM   #5
rattleNsmoke's Avatar
X2. Then use the filter housing anti-freeze to pour down your sink\shower traps.
rattleNsmoke is offline   Reply With Quote
Old 12-29-2012, 07:15 PM   #6
thanks everyone
Old 12-29-2012, 09:52 PM   #7
jimh's Avatar
i unscrewed the fittings from each side of the filter and inserted a 1/2" nipple. the fittings are hand tight so it didn't take any time at all.
last year, i used the soda pop bottle method.
Name:	water filter bypass.jpg
jimh is offline   Reply With Quote
Old 08-16-2013, 02:19 PM   #8
Has anyone having your new sunseeker that you bought out of state be serviced for warranty can't find anyone in the Delaware area
Old 08-16-2013, 02:27 PM   #9
CampeRooo
rthrbelsewhere's Avatar
Back to the filter question...yes, remove the filter. If you have the tools and have the time, just make a stainless steel bypass plate, similar to this - Water Filter Winterizing By-Pass Plate - FP-WP100 - RV Camper Parts
(no, i don't work for them or promote their website, this is for illustration only)
Joe.
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 08-18-2013, 09:42 AM   #10
NCIC105's Avatar
I've always removed the filter and blow out lines with aid pressure...add pink stuff to drains and a little extra to get to the dump valves.
Have not filled water lines with it......
NCIC105 is offline   Reply With Quote
