Old 10-09-2016, 03:13 PM   #1
Winterizing ice maker
Looking for info on winterizing our ice maker in the Sunseeker 3010.
We hope to be out of the cold before a freeze comes, but knowing how to do it will put our mind at ease in case we need to do it.
Thanks,
Shirley
David and Shirley
2017 Sunseeker 3010DS
shirleyj62 is offline   Reply With Quote
Old 10-09-2016, 09:05 PM   #2
Chief tinkerer
Gidyupgo's Avatar
This tag was on ours.
Gary
2017 SunSeeker 3010DS
Gidyupgo is online now   Reply With Quote
Old 10-10-2016, 04:51 PM   #3
Steveanddianne's Avatar
Winertize
We have the Dominic with ice maker also I saw the red tag also it seems confusing as this the first time we need to winterize the ice maker is it something a new person can do without having a problem? The tube on the ice maker that goes to the ice maker frlm the. Selinoid is copper so other than disconnecting it do you have run compressed air through that pipe it doesn't look to easy? Thanks
Steveanddianne is offline   Reply With Quote
Old 10-10-2016, 05:08 PM   #4
As I have indicated to others, put a compressor on the entire RV and blow out the lines. Leave the compressor attached overnight with the reefer turned on and the icemaker cycling. By morning it will have run enough to purge the water from all the lines. On my coach, I then turn off the feed to the reefer and pump pink antifreeze through the rest of the unit.
2015 335DS
ScottBrownstein is online now   Reply With Quote
winter, winterize
