Old 03-24-2015, 01:35 PM   #1
Winterizing Kit
Not really the time of the year for this, but we went on an early trip a couple weeks ago and the temperature has been going into the 20's at night and have been running heater. Doesn't look like we're in the clear for the temperature, so I decided to get a winterizing kit. I have a 3010, and had to pull off the black plastic in front of the pump to get to it. Do you have to modify the piping, because I don't have nearly enough room to fit this in. It has a plastic female to female adapter and then the 3 way fitting. I temporarily just screwed the hose on to get it winterized but was hoping to hear what you have done to make it work. Thanks
Brian217 is offline   Reply With Quote
Old 03-24-2015, 04:46 PM   #2
Alright, so I wound up finding an old post from 2012 on this. The pipes look a little different on the 2012 than the 2015, but same idea. I had to cut about 2 3/4 inches off the top blue pipe. Also needed to get a regular hose clamp because I don't have the tools for the pex pipe. Here's a couple pictures. It'll be nice to not have to dump it in the fresh water tank now.Click image for larger version
Name:	ImageUploadedByForest River Forums1427233540.407027.jpg
ID:	72105Click image for larger version
Name:	ImageUploadedByForest River Forums1427233560.673939.jpg
winter, winterize
