Old 10-19-2018, 07:11 AM   #1
soulman327's Avatar
Winterizing questions
that I didn't find while searching.
1. I have an air hose connection that I could hook up to the city water connection to blow out the lines. Maybe a dumb question but can the antifreeze be drawn through the system with the water pump through the city water connection in a similar fashion by hooking a small section of garden hose and putting the other end in the antifreeze?
And if that's a foolish idea that won't work, then...
2. I have the set up that hooks to the water pump (suction side from what I've read) to pump in the antifreeze. Having no owner's manual, can someone please tell me which side of the pump is the suction side? I have a picture of the system, if needed.
This is on a 2012 3170DS
Thanks again!
"If I was any better, I'd be dead!"
"The sun's always shining, otherwise it would be dark!"
"God looks out for the stupid, so I keep Him pretty busy!"
2012 Forest River Sunseeker 3170 DS 32' w/2 slides
soulman327 is offline   Reply With Quote
Old 10-19-2018, 07:25 AM   #2
Shredder's Avatar
Suction side is the left side of the pump
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 10-19-2018, 07:30 AM   #3
fonzie's Avatar
Suction side is the one with the in-line strainer (clear plastic bowl) shown in picture....
Name:	Water pump winterization kit 2 after.jpg
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-19-2018, 07:34 AM   #4
If I'm following what you're describing...
1. No, I dont think you would be able to use the city water input for antifreeze unless you build something that pumps antifreeze into it.
2.The pumps I've dealt with all have a water filter / strainer on the input side. That's one way to tell without tracing the plumbing to where it goes...but it shouldn't be too difficult to follow the plumbing. Fresh water tank is connected to in. Out typically connects to blue pex after a short run. Good luck.
Skip12 is offline   Reply With Quote
Old 10-19-2018, 08:53 AM   #5
soulman327's Avatar
Shredder, Skip12, and Fonzie - Perfect! That is exactly what I needed to know.
Thanks!
winter
