Old 11-18-2015, 02:53 PM   #11
UmptySquat's Avatar
Originally Posted by Iwritecode View Post
If it's only worn at the base, then it's still got a lot of life left.
Thanks for the education! I didn't know that! I thought it eroded equally across the length. Saved me some $!
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 11-18-2015, 10:27 PM   #12
MNtraveler's Avatar
Originally Posted by trdutch View Post
I've noticed my last 6 or so trips that my hot water pressure isn't great especially in the shower (not a full spray and a lot of dribble)
I got to wonder if all the debris I got out of the tank may have been hindering the outflow?
You might find some crud inside the shower tubing and behind (or inside) the spray head. I did - on a new unit! Some construction debris worked its way right up to the end. I wonder how much didn't.
MNtraveler is offline   Reply With Quote
Old 11-18-2015, 11:04 PM   #13
mlatter's Avatar
I assume that piece is the cold water inlet pipe that deposits the cold water at the bottom of the tank so you can draw hot water from the top. With that missing, you'll get immediate mixing of cold and hot so the water you draw won't be as hot as it should be. I had the same issue with my home water heater and symptom was lukewarm "hot" water.
Originally Posted by SilhouettePenny View Post
Pulled my anode rod to winterize today and got this black tube flowing out. Looks like a small amount of pipe dope on the broken part, hope it does not affect hot water operation next month.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 11-19-2015, 05:48 AM   #14
trdutch's Avatar
That's a good point!
When I removed the small screen bowl on the water pump to complete draining my system I found a small Plastic zip tie
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-19-2015, 06:49 AM   #15
Wolverine 1945's Avatar
I am guessing you may need to take the shower head apart and clean it,,, or replace it ??? Probably should also check faucet screens !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-19-2015, 03:11 PM   #16
Class C Representative
Joshua Cavitt's Avatar
Depending on the time yours was built it may not have an Anode rod. We used a suburban water heater that did have one but switched at some point to an Atwood aluminum tank water heater eliminating the need for an anode rod.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 11-19-2015, 09:35 PM   #17
Garrette's Avatar
Good News, your home water has the same crud. And an anode. Your home water could use the same service. Just say'in.
Garrette is offline   Reply With Quote
Old 11-20-2015, 08:48 AM   #18
Right On Garrette,,,
But it is a lot easier to drain RV WH,,,
than the 40 gal. WH that is in our basement !!!
I have see the time I tried to drain old house WHs & there was sooo much crud in them,,, it would plug up the drain value !!!
Old 11-20-2015, 09:19 AM   #19
Caution! Watch your step calling this (White Stuff) CRUD! I got for using that Term! Youroo!!
Old 11-20-2015, 04:02 PM   #20
Garrette's Avatar
You do have a point I just connect a hose and run it out the back door. At least check anode. That is the life of a water heater.
tank
