Old 11-16-2015, 02:03 PM   #1
trdutch's Avatar
WOW the crud that came out of HW tank
Winterized today and after emptying the Hot Water tank,(and bypassing it) decided to flush it with my thin spray hose attachment
Minerals and chunks just kept coming out,I mean BIG chunks like small rocks I assume fell off of the anode rod
I recommend flushing.
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-16-2015, 05:16 PM   #2
I didn't have a way to flush mine at the camper lot so will have to do it in the spring. Judging from my massively corroded anode rod, I expect lots of junk to come out.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
gmacklem is offline   Reply With Quote
Old 11-17-2015, 01:01 PM   #3
knockando's Avatar
Flushed for the first time this Fall and sounds like mine was similar to your discharge. Previous owner didn't use a lot (2010 - 10K miles) and never flushed the tank. That being said, the anode rode looked almost new. Will be an annual event for us now!
knockando is offline   Reply With Quote
Old 11-17-2015, 08:02 PM   #4
UmptySquat's Avatar
My TT only saw half a season b/c it was new. Still when I pulled my anode rod to winterize it was nearly eaten through at the base (threads). Rest of the rod looked relatively good. Guess I'll be getting a new one in the spring.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 11-17-2015, 09:26 PM   #5
SilhouettePenny's Avatar
Pulled my anode rod to winterize today and got this black tube flowing out. Looks like a small amount of pipe dope on the broken part, hope it does not affect hot water operation next month.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 11-18-2015, 12:16 PM   #6
trdutch's Avatar
I've noticed my last 6 or so trips that my hot water pressure isn't great especially in the shower (not a full spray and a lot of dribble)
I got to wonder if all the debris I got out of the tank may have been hindering the outflow?
'78.....tents
Old 11-18-2015, 12:32 PM   #7
2015 Apex 288BHS
If it's only worn at the base, then it's still got a lot of life left.
Iwritecode is online now   Reply With Quote
Old 11-18-2015, 01:36 PM   #8
If we aren't planning to use the MH for a while I always drain and flush the HW tank. It also saves on the anode rod. I have 3 years on the Suburban anode rod and it is at about the 50% level.
edcronin01 is offline   Reply With Quote
Old 11-18-2015, 02:03 PM   #9
Flybob's Avatar
I used a threaded/slip fit connector and a 6" pc of PVC to make an adapter that screws into the WH (once Anode is removed) You can slide a clean out wand inside it and flush the WH. The adapter keeps the crud that flushes out off the side of the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-18-2015, 02:28 PM   #10
frozen's Avatar
It's likely that the "crud" that flushes out of the water heater is minerals from hard water rather than pieces of the anode rod. The rod probably doesn't erode in "chucks". They can look terrible, but still function just fine.
Put un-softened tap water in a dark-colored pan or kettle, heat it until much of the water has evaporated, then look at the walls of the kettle; they'll be coated with gray/white minerals (largely calcium and magnesium), the same stuff that comes out of the water heater. Don't panic; we all need those minerals for good health.
frozen is offline   Reply With Quote
Old 11-18-2015, 03:53 PM   #11
UmptySquat's Avatar
Thanks for the education! I didn't know that! I thought it eroded equally across the length. Saved me some $!
2015 Apex 288BHS
Old 11-18-2015, 11:27 PM   #12
MNtraveler's Avatar
You might find some crud inside the shower tubing and behind (or inside) the spray head. I did - on a new unit! Some construction debris worked its way right up to the end. I wonder how much didn't.
MNtraveler is offline   Reply With Quote
Old 11-19-2015, 12:04 AM   #13
mlatter's Avatar
I assume that piece is the cold water inlet pipe that deposits the cold water at the bottom of the tank so you can draw hot water from the top. With that missing, you'll get immediate mixing of cold and hot so the water you draw won't be as hot as it should be. I had the same issue with my home water heater and symptom was lukewarm "hot" water.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
mlatter is offline   Reply With Quote
Old 11-19-2015, 06:48 AM   #14
trdutch's Avatar
That's a good point!
When I removed the small screen bowl on the water pump to complete draining my system I found a small Plastic zip tie
'78.....tents
Old 11-19-2015, 07:49 AM   #15
Wolverine 1945's Avatar
I am guessing you may need to take the shower head apart and clean it,,, or replace it ??? Probably should also check faucet screens !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-19-2015, 04:11 PM   #16
Class C Representative
Joshua Cavitt's Avatar
Depending on the time yours was built it may not have an Anode rod. We used a suburban water heater that did have one but switched at some point to an Atwood aluminum tank water heater eliminating the need for an anode rod.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 11-19-2015, 10:35 PM   #17
Garrette's Avatar
Good News, your home water has the same crud. And an anode. Your home water could use the same service. Just say'in.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 11-20-2015, 09:48 AM   #18
Right On Garrette,,,
But it is a lot easier to drain RV WH,,,
than the 40 gal. WH that is in our basement !!!
I have see the time I tried to drain old house WHs & there was sooo much crud in them,,, it would plug up the drain value !!!
Old 11-20-2015, 10:19 AM   #19
Caution! Watch your step calling this (White Stuff) CRUD! I got for using that Term! Youroo!!
Old 11-20-2015, 05:02 PM   #20
Garrette's Avatar
You do have a point I just connect a hose and run it out the back door. At least check anode. That is the life of a water heater.
tank
