10-23-2017, 09:23 PM
#21
A note on torque wrenches. If you use the common "click" type torque wrench, always store the wrench at 0 torque lbs or whatever the minimum setting is. There is a spring inside the wrench and leaving the wrench at the setting you last used it will reduce the accuracy of the wrench. This instruction should come with the wrench, both of mine did...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
10-23-2017, 09:25 PM
#22
Who Dares, Wins
It's funny you say this, my hf wrenches also came with instructions on how to send it back to them or yearly calibration.. I'll buy a new one for 14.99...
2015 Chevy HD D-Max
2022 Impression 315MB
10-23-2017, 09:30 PM
#23
Yah, the 100 lb wrenches aren't too bad to replace. My 250 lb wrench has a steeper price tag..
Al
10-23-2017, 09:32 PM
#24
Who Dares, Wins
Yeah.. I have a nice one.. It was great until my father got a flat near my house and used my "breaker bar " to loosen the lugs on his lowboy trailer..
2015 Chevy HD D-Max
10-23-2017, 09:36 PM
#25
Originally Posted by jimmoore13
A torque wrench is another matter, and it's a good option to apply precise torque on a nut. I don't use one for lug nuts.
For day-to-day use, I have these in my truck:
Heavy-duty lug wrench. The telescoping handle makes it very powerful, yet it collapses nicely to store in the vehicle. Mine, from Walmart, has two double-ended sockets that have a 1/2" drive adaptable to use with a torque wrench--requires a short extension. The sockets fit nicely into the recesses in alloy wheels.
Folding 4-way wrench This is handy to spin the lug nuts while loose--an otherwise tedious process. It, too, stores easily.
Both fit everything I've owned thus far since I bought them: 4 cars - Isuzu Rodeo, Ford Explorer, Dodge Ram 1500, Toyota RAV 4 - and two PUPS.
If you are saying you just tighten them up without any accuracy you should re-think that. http://www.forestriverforums.com/for...ies/crying.gif.
If you don't torque you are playing with fire. http://www.forestriverforums.com/for...s/campfire.gif
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
10-23-2017, 09:37 PM
#26
Not a big fan of Harbor Freight. I would buy elsewhere. Quality tools are worth the price.
10-23-2017, 09:39 PM
#27
Who Dares, Wins
In a test done by the family handyman magazine hf scores tops for their torque wrench, I was shocked. Now this was a budget friendly test, not unlimited funds, but based on the handymans needs
2015 Chevy HD D-Max
10-23-2017, 09:42 PM
#28
$12 right now.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
10-23-2017, 09:43 PM
#29
Who Dares, Wins
Good old weekly parking lot sales
2015 Chevy HD D-Max
10-23-2017, 09:52 PM
#30
Good advice. Another piece of advice (and I don't know if this is included in the instructions)is to always "click up" to the desired torque setting. In other words,if the desired setting is 100 pounds, click up to 100 from say 80-90 pounds. I was taught this in the military as well as in commercial aviation. Another thing taught was to exercise the spring by turning the wrench from a low serving to its highest setting occasionally.
10-24-2017, 06:45 AM
#31
Tinkerer and Putterer
Originally Posted by Waterops1
I should have added in my earlier post,, use 6-point sockets!! The lug nut I messed up was done with a 12-point socket. As a previous poster said, he had used a spark plug socket. Wished I had purchased more 6-point sockets when I started buying Craftsman tools in 1969. I now make certain to have 6-points in my flyaway tool kit.
I tossed my 12 points into a hole. I'm too cheap to get rid of them completely, I might be able to use them to make a tool some time, but I never use them because they round off corners.
10-24-2017, 07:19 AM
#32
That is why impact sockets are recommended. They are all 6 point. I still like the old fashioned beam torque wrench. Have one and still use it. I do like the torque sticks for doing lug nuts. Spot on every time.
10-24-2017, 02:40 PM
#33
"Curmudgeon"
10-24-2017, 03:14 PM
#34
Originally Posted by babock
I always use a torque wrench for lug nuts on all my vehicles and trailers however I don't usually carry one with me when I travel.
I always use a torque wrench for every fastener I install and that includes oil drain plugs. I have worked in some manufacturing environments and torque wrench use is the norm so it just follows into my home mechanical usage.
I use that same lug wrench that jimmoore13 uses from Walmart. I just make sure I use a torque wrench when I get home. Fortunately, I don't have to use it often.
I always use a torque wrench on the lugnuts before of my trailers before I head out on a trip. Seen too many people have sheared lug bolts or wheels that have come flying off.
BTW...never grease the threads. Torque values are for dry threads.
Thanks...good advice. Like you, I check my lug nuts often. My first wife was driving...following a trailer. One of the trailer wheels came off and, fortunately, bounced over her car...just dumb luck. Those behind her managed to avoid the bouncing tire, too.
I'm curious. On the occasions when you've done a "field repair", how far off are you compared to the torque wrench when you do it "by feel"? I suspect I over-tighten.
I've used one occasionally - for example to torque head bolts on an engine. I have no idea how close I come to manufacturer specs on things like lug nuts.
Again, good advice.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
10-24-2017, 03:26 PM
#35
I loosen when I get home and re torque. Most of the times when I have had to change a tire on the road, my next step is to get a new tire and they get retorqued with a torque wrench or torque bars at a tire store where I am replacing the tire at.
I just replaced 4 motor mounts on a Honda we have this weekend. Every fastener got torqued to the spec listed in the OEM factory manual.
