Old 05-02-2017, 08:34 AM   #1
W5CI's Avatar
Deleting PM's
My pm box is full how can I delete all of the messages ?
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 05-02-2017, 08:39 AM   #2
SeaDog's Avatar
this is how I do it. click on PM when it opens select msgs to be deleted and then at the bottom of that window there is a box that says move click on the arrow and when the menu opens highlight delete and they should go away.
I not an admin person so this may not be the correct procedure but has worked for me
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-02-2017, 08:48 AM   #3
Bacchus's Avatar
You can also use the shift key to select a range of messages or the command key to select individual messages. I am not an admin person either.
2017 Flagstaff Shamrock 21ss pulled by a 2007 Ford F150 XLT 4X4
Bacchus is offline   Reply With Quote
Old 05-02-2017, 09:03 AM   #4
wmtire's Avatar
1. You can go to your inbox or sent folder of PM's. When the list appears, select the checkbox at the top and to the right of the number of messages. This will select every message on the page. (the checkbox would be to the right of the #1634 in my pic below)
2. Now scroll down to the bottom of the message list at the bottom right, and select the dropdown arrow box of "selected messages" for a list of options for things to do with your selected messages. It's default is "move to folder", but after you click on the arrow, you have more options including delete.
If you just want to delete them, then select delete. After selecting delete, then click on the GO button to the right of it.
You will need to do both for your inbox and sent box if you want both deleted.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, that’s my motto.
