Old 02-03-2016, 12:22 AM   #1
Editing posts
Just wondering how to edit post?
mkccmc is offline   Reply With Quote
Old 02-03-2016, 12:32 AM   #2
Who Dares, Wins
doc73's Avatar
Along the bottom edge of your post is an edit clicker.. In the app (Android for me) it is a pencil. It does go away after some time though so you need to change it fairly soon. If it still needs and edit, a PM to a mod can either change the post or have the edit turned back on.
EDIT: The clicker is between the "thanks" and "Quote" on the web site..
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 02-03-2016, 12:59 AM   #3
asquared's Avatar
Doc is correct.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-03-2016, 10:31 AM   #4
Thanks. Was just asking because I did a recent post and there was no icon to edit.
Old 02-04-2016, 12:46 AM   #5
Still can not seem to figure out how to edit. I see the pencil icon but when i click it it just opens new window and does not let you edit your original post?
Old 02-04-2016, 01:39 AM   #6
asquared's Avatar
What are you using, tapatalk, FRF app or full site? How old is the post?
2014 Sabre 34REQS-6
Old 02-04-2016, 01:43 AM   #7
asquared's Avatar
From our forum FAQ section: this applies to the full site.
an I edit or delete my posts?
If you have registered and are logged in, you may be able to edit and delete your posts (although the administrator may have turned off this option). Your ability to edit your posts may be time-limited, depending on how the administrator has set up the forum.
To edit or delete your posts, click the Edit Edit / Delete Message button by the particular post. If your post was the first in the thread, then deleting it may remove the entire thread.
Once you've made your modifications, a note may appear to inform other users that you have edited your post.
If the edit time and date appear as a link you can click on this to see the differences between the original and edited versions, or between edits if there have been multiple edits.
Can others edit my posts?
Administrators and moderators may also edit your messages. If they do, there may not be a note telling other users that the post was modified.
I can tell you when posting from my iPhone I have trouble using some features. It may also be that the time period has passed.
2014 Sabre 34REQS-6
Old 02-04-2016, 01:47 AM   #8
asquared's Avatar
Mkccmc I have temporarily turned on the edit button to your latest test post. See if you are able to do anything now.
2014 Sabre 34REQS-6
Old 02-08-2016, 12:19 AM   #9
Edit Post
no still can not edit post? When i click on the edit tab it just opens new window that says quick reply?
Old 02-08-2016, 12:34 AM   #10
asquared's Avatar
Try going to the full site it might be easier. If the post is too old, you can't edit it.
2014 Sabre 34REQS-6
Old 02-08-2016, 12:40 AM   #11
what is the full site. I am using my mac book pro?
Old 02-08-2016, 12:55 AM   #12
asquared's Avatar
Is this the screen you see when you try to edit the post?
2014 Sabre 34REQS-6
Old 02-08-2016, 12:59 AM   #13
asquared's Avatar
If on mobile site scroll to the bottom of the page. In the black section with white lettering, next to social knowledge it will say "full site". Click that to go to full site. If you already are in the full site, then when you scroll to the bottom. On the left hand corner in the green will be a drop down box that reads "forest river v2.0"
2014 Sabre 34REQS-6
Old 02-08-2016, 01:31 AM   #14
Yes sir already on full site.
Old 02-08-2016, 06:01 PM   #15
asquared's Avatar
So is this what you see when you try to edit? If so that is correct.
2014 Sabre 34REQS-6
Old 02-25-2016, 12:54 AM   #16
Bummer still can not edit posts.
