Old 02-10-2019, 01:12 AM   #1
Retired Old Fart
dward51's Avatar
Extra lines between paragraphs in posts?
I tried to see if I could find anything on this in the forum help and faq area but did not see it.
For some reason my posts have an extra line between every paragraph in the initial post. I can go in and edit the post to take the extra lines out, but that gets old. It looks fine in preview, but once posted it is double spaced between the paragraphs. Is there some setting I missed or am I doing something wrong. I'm not having this issue in any of the many other forums I participate in, just this one.
I'm not editing this part of the post so you will see the double lines between the paragraphs "as is".
I did go in and edit the same text with a single line between paragraphs here:
I'm not editing this post so you will see the double lines between the paragraphs.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 02-10-2019, 10:14 AM   #2
Just hit return twice and start typing. Ignore the cursor position. The extra line will show up eventually.
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2012 F150 5.0L Scab
mawilson is offline   Reply With Quote
Old 02-10-2019, 10:44 AM   #3
rsdata's Avatar
Much ado about nothing?
Lots of posters do little to spell or grammar check or even to reread to make their posts actually make sense...
Like this title here...
Frozen fresh water tat
Yours look great, extra line or not.
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 02-10-2019, 02:34 PM   #4
Retired Old Fart
dward51's Avatar
Ok, I guess it is what it is and I'll have to get used to it.
Old 02-11-2019, 02:02 PM   #5
Hi,
My posts do that too. I immediately go to the Edit function and fix it.
FWIW.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is online now   Reply With Quote
Old 02-11-2019, 05:30 PM   #6
What browser? What OS?
What browser are you using? What Operating System? Are you using Tapatalk or another one of those "helpers"? Can you try a different setup?
Larry
Larry-NC is offline   Reply With Quote
Old 02-11-2019, 06:43 PM   #7
Just as confused as you
Scrapper's Avatar
My laptop started doing the same thing about 6 months ago. As I'm typing everything looks fine but changes to double space when I click Post Reply. It is annoying.
I am on a Win10 gaming laptop using Firefox signed in on Forest River Forums - Forest River Owners Community and I don't use anything else.
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 02-11-2019, 07:18 PM   #8
Just for fun...
Just for fun, try using a different browser for a test. Maybe Edge, the one that comes with Windows 10. If the problem doesn't occur, it's a Firefox problem.
Larry
Old 02-11-2019, 07:28 PM   #9
Flybob's Avatar
Has to do with the text font selection in some browsers. I need to go back and find the solution.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-11-2019, 08:39 PM   #10
Scrapper's Avatar
Larry
It has something to do with FRF, as dward51 mentions no other forum has this problem.
I absolutely will not use MS Edge. Though Microsoft advertised it as better than IE, it is an integral part of Win10 and it still uses IE as it's base software. There is no way to completely disable nor is there a way to uninstall either one from Win10 Home.
Richard & Jill
