Old 06-14-2018, 01:34 PM   #1
rv frame supporting electirc steps FR3 32s
I own a 2016 FR3 32ds . I noticed the left side of my steps would sag when you stepped on them. I got under the rv and found out that the frame that the steps are attached to has partially broken on the end allowing the step to sag when using. the right side of the step is ok.
I believe the metal angle is not strong enough to support the steps.
The dealer I purchased the unit from is worthless. Any suggestions how to repair?
gpierce75 is offline   Reply With Quote
Old 06-15-2018, 08:15 AM   #2
SeaDog's Avatar
Hard to visualize the problem maybe if you add a pic folks will be able to give some advice on how to repair/strengthen the area
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
fr3, frame
