11-20-2013, 12:04 PM
Site Downtime Wednesday Evening
Folks we have a server upgrade planned and anticipate that the forum will be offline for about 15 minutes late in the evening EST. Once we're back online you should see increased page load speed. Thanks in advance for your patience.
11-20-2013, 12:21 PM
Thanks for the heads up.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
11-20-2013, 01:15 PM
Thanks Janet!
11-20-2013, 05:21 PM
Always Learning
It'll be a very dark 15 minutes!
11-20-2013, 06:33 PM
Thanks, Janet for the heads up!
11-20-2013, 06:47 PM
OMG.....FRF withdrawals.........
11-20-2013, 06:49 PM
Good luck !
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
11-20-2013, 06:54 PM
Hope the outcome isn't like the government healthcare web site !!
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
11-20-2013, 06:55 PM
Did someone say "upgrade"......
This!
Originally Posted by Goomph
Good luck !
11-20-2013, 06:56 PM
11-20-2013, 07:06 PM
Youroo!!
11-20-2013, 07:16 PM
phat phrog stunt crew
Amen on the healthcare comparison. As far as downtime goes, pretend you are camping for 15 minutes and don't want the distraction.
11-20-2013, 07:17 PM
Watch it - you're getting close to crossing the no political discussion line here
11-20-2013, 09:40 PM
We don't get paid enough to make a website like that.
Seriously though, we should be able to do this pretty quick, but there could be some DNS lag as we move around some records. Some people may see it down a little longer than others until their DNS updates.
If you find that the site is down for you but not others, try wiping your Windows DNS cache by executing this command in your run window:
ipconfig /flushdns
Should be starting in about 20-30 minutes folks.
- Jeff
11-20-2013, 10:02 PM
ipconfig /flushdns
- Jeff
Hope all goes well because I have no idea what you just said
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
11-21-2013, 07:46 AM
I had to log back on ...
Is that good ?
11-21-2013, 11:04 AM
I can access FRF on my desktop computer, but the iPhone goes to a page which has a message that the system is down for upgrade and will be available soon.
I get the same thing in the App and using Safari. I have tried resetting all network settings on the iPhone, and I reset my router. I get the same result whether going thru my WiFi network or ATT's LTE network. I will be opening a problem with the Help Desk.
11-21-2013, 11:08 AM
I can only acces frf via a desktop.
I cannot access the app or the web version from my android phone.
11-21-2013, 11:31 AM
Always Learning
I had the same issue this morning, but later it resolved itself.
I hadn't seen Jeff's message before, but it makes sense why one would work versus another. Every web site name (aka "domain") has a numeric address behind of it (very loosely like towns and zip codes- it's easier to remember, "York, PA" instead of "17406"). There is a domain name (i.e. Forest River Forums - Forest River Owners Community) maps to a set of numbers (in this case, 162.243.61.9). The servers and hardware of the internet works off of these numbers whereas we people generally use the names.
Because it takes time for your computer, phone or tablet to do the translation (aka "name resolution") from name to number when you enter in Forest River Forums - Forest River Owners Community, this name resolution gets cached in a variety of places (your phone/tablet/computer itself, the router that connects you to Verizon, Comcast or other Internet provider, their servers and beyond). It's to help things be "more quick".
The problem comes when you switch the IPs behind the scenes which is exactly what it sounds like Social Knowledge did - they likely moved servers. It takes a period of time for the switch to occur in each device that handles name resolutions. Sometimes it's a set period of time, "this *remembered* record expires in 2 hours from this point in time" and sometimes it's a rolling period of time, "this *remembered* record expires 2 hours after the last time that it was used". (The 2 hours part is even configurable- each device decides how long it should live.)
It's that rolling timeout that can be problematic. If it's not working for you on your phone and you keep trying, that 1 to 2 to 24 hours can keep getting extended.
What Jeff recommended earlier was to flush your DNS caching. The problem is, the command that he provided was specific to Microsoft Windows. You might try restarting your devices and see if it helps. Otherwise, you can also reset network settings- I'm just not sure what side effects that has:
https://discussions.apple.com/message/20199616#20199616
Oh, and you Android users - I'm of ZERO help there. Here's a Google search that might help (the first Stack Overflow article seems to indicate that restarting may help you, too):
https://www.google.com/search?q=flus...hrome&ie=UTF-8
Good luck!
11-21-2013, 12:01 PM
You might try re-installing the mobile app if you still having trouble.
