Old 06-26-2016, 10:22 AM   #1
Kidder's Avatar
Tapatalk issues
I have been using Tapatalk since I first registered on this site. In the past week or so, it will not work. It keeps going between the app and bringing up the forum that looks like it would when you open via an Internet browser. It automatically goes back and forth and never stops. I have stop following the forum and tried to add it back with the same symptoms.
I use Tapatalk with other forums with zero issues.
Kidder is offline   Reply With Quote
Old 06-26-2016, 10:37 AM   #2
wmtire's Avatar
Thanks for letting us know. I am currently using Tapatalk to read and reply to your post.
Is anyone else having similar problems?
Sent from my Z958 using Tapatalk
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 06-26-2016, 10:44 AM   #3
I'm on it now with no issues.
Old 06-26-2016, 10:46 AM   #4
Kidder's Avatar
So, I logged into the browser view (I was able to stop it from going back and forth by tapping on the browser view) and now it has stopped going back and forth. This is the only forum that requires a login that way. Normally, I can use my forum Un/pw to log in with Tapatalk. So, something isn't set up properly, IMO. Also, when in Tapatalk when I select unread or participated it doesn't list those threads. Something definitely isn't quite right. I'll keep adding to this thread as I find more issues.
P.S. I had to login with Firefox to post this since I couldn't access this thread in Tapatalk.
Old 06-26-2016, 11:04 AM   #5
wmtire's Avatar
Are you using Iphone, android, or other?
Old 06-26-2016, 11:38 AM   #6
Kidder's Avatar
Android
Old 06-26-2016, 11:42 AM   #7
Kidder's Avatar
Well, I decided to uninstall the app and reinstall it and everything is good now. Weird
Sent from my SAMSUNG-SM-N910A using Tapatalk
1953 Ford NAA Jubilee
2015 Kawasaki Versys 1000 LT
2016 Ram 2500 Cummins, Crew, Longbed, 4x4
Old 06-26-2016, 11:46 AM   #8
wmtire's Avatar
Ok Great, I was going to explain how to clear the data/cache...but if you uninstalled the app, you probably already know how to get to this.
Glad you got it solved.
Old 06-26-2016, 11:47 AM   #9
Kidder's Avatar
Ok Great, I was going to explain how to clear the data/cache...but if you uninstalled the app, it you probably already know how to get to this.
I didn't even think of that. If it happens again, I will try that first and just log in again.
