Old 07-16-2018, 11:41 PM   #1
FORKLIFMAN's Avatar
Thinking about installing the MorRyde steps step above
So if I install the Morryde steps that swing up into the RV, how do you raise the steps and close the door from the inside? I only have the side door. I am thinking you need more than one way in and out of your home?
FORKLIFMAN is offline   Reply With Quote
Old 07-16-2018, 11:56 PM   #2
I haven’t seen the step above on a motor home and due to the length and design I don’t think they’re intended for use on one.
John Taylor
2019 Newmar Bay Star 3609
2018 Cardinal 3350RLX - sold
2013 Cardinal 3030RLS - sold
jtaylor1920 is offline   Reply With Quote
Old 07-18-2018, 05:21 PM   #3
Always Learning
I always thought of these for travel trailers and fifth wheels. Have you contacted MorRyde about applicability for motorhomes?
Old 07-18-2018, 11:59 PM   #4
FORKLIFMAN's Avatar
found solution, they make a quick connect step. I will keep my unsafe lippert steps for accessing in and out. When setting up I will put on the MorRyde steps, Steps on Lippert
Snapped the stud on the bearing, I was able to drill out the bearing and installed grade 8 bolt.
Thanx for responses and advise!
