Old 08-24-2016, 07:10 PM   #171
Newbie
Does anyone with a 2104s have a counter extension? If so could you share details and possibly pictures? Thanks!
Susan & Jim
2014 Ford F-150 (white, of course!)
2015 Rockwood Mini Lite 2104s
SusanO is offline   Reply With Quote
Old 08-31-2016, 07:17 PM   #172
Dual-Fuel Generator
We are wanting to buy a new, larger generator so we can run our 13,500 AC. Before purchasing, I'm hoping to get some confirmation from those I trust - you! The Champion model we are looking at is the 2800-Watt Running/3100-Watt Peak. These are the numbers for running on gasoline. However on propane, it is 2520-Watt Running/2800-Watt Peak. Will this run our AC on propane???
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
Old 08-31-2016, 07:20 PM   #173
I should further state that we seldom need AC. And, that we have no problem turning off other big draws on those occasions we want to use our AC.
2016 Rockwood 2504S
Old 09-04-2016, 01:07 PM   #174
Smile battery cut of
I have a 2015 Micro Mini 21DS and after having to charge the batteries I can not get the side to close.
did I trip a switch when the batteries were removed and where would it be located. i have heard or read that Flagstaff is tricky were they put battery cut off.
Thanks for any help
2015 Forest River 21 DS
1999 F350 super 7.2 diesel
Showing basenjis
almasibasenji is offline   Reply With Quote
Old 09-04-2016, 04:56 PM   #175
I don't know about flagstaff but our rockwood has a fuse that can blow causing no power to the slide. It is located in a little case on a wire running under the tongue, street side, between the battery & the camper.
2016 Rockwood 2504S
Old 09-05-2016, 07:34 PM   #176
We just had the same problem with our 25FKS, the slide out inline fuse blew out on the tongue. It's a 30amp available at any parts store or Walmart
Old Legend is offline   Reply With Quote
Old 10-13-2016, 01:00 PM   #177
Did anyone get a base for their Furrion 24" FEHS24T84 when they bought their Mini-Lite? Ours is a 2017 and did not come with a base and I am looking for one as I swapped the TV (an am using in the house) for our 19" Insignia which runs on 12 volts.
If you have one you want to part with, please let me know-I'd be happy to pay the shipping!
Campah
2017 Rockwood 2109s Mini Lite
Campah is offline   Reply With Quote
Old 10-13-2016, 11:46 PM   #178
I did NOT get a base.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 10-14-2016, 07:47 AM   #179
SkipBest's Avatar
No base here. It would be useful if using at home.
SkipBest is offline   Reply With Quote
Old 10-14-2016, 07:48 AM   #180
SkipBest's Avatar
Our cutoff is under the propane tank on the port side.
