Old 02-12-2015, 06:38 AM   #21
Jhochst's Avatar
Mini lite micro lite group
That sounds great. Guess I will be pulling trigger on the add on unit or research a little on paddle unit
Jhochst is offline   Reply With Quote
Old 02-12-2015, 06:44 AM   #22
Jhochst's Avatar
My ac cover is brown and antenna white. Wasn't happy about that. But just seen this.
Name:	ImageUploadedByForest River Forums1423741525.737688.jpg
Old 02-17-2015, 09:31 AM   #23
Anybody using the Anderson levelers on their Micro or Mini? If so, how much did you have to cut off to fit between the tires.
Papa GLS is offline   Reply With Quote
Old 02-19-2015, 12:18 AM   #24
genecusano's Avatar
Thermostat
I would like to replace the present thermostat in my 2013 21fbrs. I have not been able to find any. Is there someone that has done this?
Gene & Betty
2011 Silverado
2013 Flagstaff Micro Lite 21 FBRS
Mission, TX
2013-100..2014-180..2015-175..0
genecusano is offline   Reply With Quote
Old 02-19-2015, 10:35 AM   #25
GlacierGus's Avatar
If you type in "replace thermostat" in the "search" box near the top of the page you will find other discussions on this topic. Look around and see if any work for you. If you do replace your thermostat let us know what you replaced it with and how easy was it to wire. Pictures help greatly. Inquiring minds always want to know. I'm fairly handy with electrical wiring but I haven't tried this yet.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 02-19-2015, 11:00 AM   #26
KDHfan's Avatar
Although a former 2306 Mini owner, I'll chime in. We traveled with 2 bikes inside the camper and 1 in the back of the truck.
Loved the versatility of the Mini. Never had to worry about length. Our favorite two campgrounds are Clear Creek State Park (PA) and Hershey (Hershey Park Campground and Jonestown KOA are recommended)... (Hershey KOA not recommended).
We had a 3" standard queen memory foam on top of our mattress. Made the bed a little longer and standard queen sheets fit well.
As far as a towel rack, we put an over-the-door coat rack onto the bathroom door and used it as a towel rack.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 02-21-2015, 04:04 PM   #27
We are trying to learn all we can about the minis and micros before we get one - which we can't until the end of this camping season. We've already learned a ~lot~ here. We haven't seen anybody talking about raising their TT to go over rough/rocky roads, though. Has anyone in this group done such a thing? (We did on our PUP, and it helped.)
Ash and Jim
and Wee Dram the Westie
2014 Rockwood HW276; 2008 Ford F150 V8 5.4 ltr. King Ranch
AshnJim is offline   Reply With Quote
Old 02-21-2015, 07:25 PM   #28
KDHfan's Avatar
I replaced my analog unit with a digital one on my former TT, a 2306. It was a Coleman Mach. I found it on Amazon. Took about 5-minutes to change it out. Just make sure you match up the mfg and the functions properly (FAN: on/off/auto, COOL: on/off, HEAT: on/off).
Old 03-01-2015, 07:50 PM   #29
SkipBest's Avatar
Any interesting uses for the Murphy Bed shelve? It looks like a neat space.
Skip
SkipBest is offline   Reply With Quote
Old 03-18-2015, 12:13 AM   #30
Chevy Two's Avatar
Originally Posted by SkipBest View Post
I started a new social group for Lite Fans.
I hope I did it correctly???
Click in and join us if your into "Lites"
SkipBest : Count us in the group (Lite Fans). We are new to FRF and camping. We've only camped two times before the weather set in here. 1). Driveway camping,and a long weekend @ Stone Mountain Ga. The first camping trip was a very large learning curve, but we made it. The second one was much better but still have a lot to learn !!!
With the downtime of not camping I added a few things to the camper. First thing I added was a power tongue jack (to old I guess) should make things a lot easier now.😃 . Also added two Max-Air vent covers. A Lend-a-Hand rv hand rail (that old thing again).
The DW and I like to BBQ/ slow cook with a smoker. So I built a mini smoker,a set of Red Neck wheel clocks.Click image for larger version
Name:	ImageUploadedByForest River Forums1426651906.690959.jpg
ID:	71634Click image for larger version
Name:	ImageUploadedByForest River Forums1426651923.438596.jpg
Sent from outer space! 🇺🇸😄😄🇺🇸
Chevy Two is offline   Reply With Quote
