Old 02-11-2016, 01:01 PM   #51
No problems at all with closing it with all bedding on. Don't remember dimensions. Just remember trying to find a pad with closest dimensions to the bed. Ordered online from somewhere. ..
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-11-2016, 03:44 PM   #52
Thank you - we'll definitely get one before we take it out the first time!
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
Old 02-12-2016, 05:05 PM   #53
KDHfan's Avatar
Mini lite micro lite group
Originally Posted by Doxies in the Rockies View Post
Thanks for the quick response! So a 3" pad will still allow the bed to fold up ok? Is yours a queen short or regular length pad? Do you have bedding over it? We've had a cold winter here in CO also, but we're having temps in the low 60's for the next week!
We had a 2306 with Murphy bed. We had the stock mattress (short queen), a standard queen 3" memory foam, and a mattress pad, with the fitted sheet over the foam & pad... Then a sheet and a heavy blanket on that. With the pillows at the head of the bed, it fit snugly against the wall.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 02-12-2016, 05:28 PM   #54
Thank you! It sounds like the pad I found at will work perfectly!
Old 02-12-2016, 05:41 PM   #55
Originally Posted by SkipBest View Post
Topic questions:
In your M Lite travel...
Do you travel with bikes? Where do you store them? Do you use a rack?
Have you made any modifications to your M Lite?
IF you have a slide does it function alright?
If you camp at one place where are you located?
If you use your M Lite to travel where is your favorite spot... so far?
Nancy has "interior" questions...
What sheets do you use? Camping world short queens?
Here is one, where do you put your trash can?
Have you added any towel racks?
Any tricks for storing things in cabinets during travel?
Well there are a few thoughts to start things off... What is on your mind?
Skip and Nancy Best
I have a 2016 Mini Lite 2503S, delivered June 2015
Dealer installed 2" receiver with beefed up supports on back (he did similar on my Roo 19). No problems so far carrying 2 bikes.
1. Switch/pilot light for hot water heater electric element
2. Honeywell RHB111B digital thermostat
3. Fencepost sewer hose holder
4. PVC pipe WDH spring bar holder
5. BAL Hide-a-Spare for spare tire
6. Bike receiver as discussed above
7. 4 pin connector for bike rack lights
8. Routed fresh water tank drain to side of trailer
9. 110VAC outlet on street side sofa table
I've posted pics of most of these on other posts.
So far, so good.
Camp all over Mid-west.
None standing out at this time.
Normal queen sheets, use some stretchy things (technical term) across the corners that take up the slack.
To right of the kitchen, in front of the wardrobe
Not yet. DW hasn't decided what/where.
Go to Walmart/Target, etc and look for various shelves, boxes, etc.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 02-12-2016, 06:25 PM   #56
Blackrock's Avatar
Went a little crazy
The bathroom in out 25DS is pretty cramped for us when on the stool. Just not enough elbow room. Also when getting out of the shower we wanted more swinging room. I am 6' and 280# and DW is a bit wide as well.
So I cut out the wall and removed the door. Got some hardwood trim and stained to match. Put up a rod (3/4" emt) and a pretty curtain. The rod is hinged on one end and had clips to hold it in two positions. Swing it out and latch it to the wall by the fridge or just leave it straight.
I also replaced the analog tstat with a digital and mounted it out where it was easier to get to.
ID:	99496   Click image for larger version
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is online now   Reply With Quote
Old 02-15-2016, 07:19 AM   #57
53flattie's Avatar
1.Switch/pilot light for hot water heater electric element
2.Honeywell RHB111B digital thermostat
3.Fencepost sewer hose holder
4.PVC pipe WDH spring bar holder
5.BAL Hide-a-Spare for spare tire
7.4 pin connector for bike rack lights
8.Routed fresh water tank drain to side of trailer
9.110VAC outlet on street side sofa table
So far, so good.
Can you give any details or pictures on #4 - the spring bar holder?
2015 Rockwood 2306
2015 Tundra CrewMax
53flattie is offline   Reply With Quote
Old 02-15-2016, 04:22 PM   #58
2015 Rockwood 2306
2015 Tundra CrewMax
Basically a take on the fence post mod. Gives me a place to put the spring bars while in camp. Used 2" PVC pipe.
Name:	Hitch Bar Holder 3.jpg
ID:	99661   Click image for larger version
Name:	Hitch Bar Holder 5.jpg
ID:	99662   Click image for larger version
Name:	Hitch Bar Holder 6.jpg
ID:	99663   Click image for larger version
Name:	Hitch Bar Holder 8.jpg
ID:	99664   Click image for larger version
Name:	Hitch Bar Holder 9.jpg
Old 02-16-2016, 06:54 AM   #59
53flattie's Avatar
Very smart idea. Thanks for sharing.
2015 Rockwood 2306
2015 Tundra CrewMax
Old 02-18-2016, 08:39 PM   #60
Newbie
Where are your pvc tubes mounted to when camped? I just put my bars in the back of the truck.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
