Old 06-04-2014, 08:40 AM   #31
Ford Idaho's Avatar
Originally Posted by Kaadk View Post
Nope, just an ordinary cooking sheet. Though the friend who first gave us oven cooked bacon used a broiling pan.
She google's the recipe every time she makes it, but as we just did it the other day I believe it was:
- Put bacon on sheet
- Put sheet in cold oven
- Set oven to heat to 400F
- Check after 17-20 minutes, depending on oven, thickness of bacon, etc...
- When done, transfer to paper towels to absorb excess grease.
If you put in a second batch, you'll need to reduce cooking time accordingly as the oven will already be warm.
I was thinking the broiling pan because it gives the grease a place to go, what does she do for/about the grease when using a sheet pan?
Old 06-04-2014, 08:43 AM   #32
Kaadk's Avatar
Pours it in a can. No different than having to pour the grease out of a frying pan.
Addendum: If you have a broiling pan, then just try both and see which you prefer. With the sheet it'll cook in it's own grease, adding a bit of tenderness, with the broiler, you should get a crispier bacon.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 06-04-2014, 08:48 AM   #33
Ford Idaho's Avatar
Ok, broiler it is, crispy bacon is a must have.
Old 06-04-2014, 09:04 AM   #34
Kaadk's Avatar
DW likes crispy bacon too, but still prefers the sheet over the broiler. Try both, see which you prefer.
Old 06-04-2014, 09:13 AM   #35
Arefbee's Avatar
At home I use the broiler and have less residue around the house.
At the CG we put a griddle on the portable gas BBQ and it works great. Frankly I was really bummed not having bacon and walking outside on a Saturday morning into the cloud of bacon-ness wafting from every other camper in the park... which could have been my imagination exaggerating a little.
I would not mess around with covering the smoke detector. If you forget to remove it one time, it could be fatal.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 06-06-2014, 06:27 PM   #36
Cooking bacon in the trailer is a "NO, "NO. Outside on the grill. No after smell inside.
Gee Whiz is offline   Reply With Quote
Old 06-10-2014, 07:17 PM   #37
RV Nomad
Ours doesn't like toast or bacon either. I have been cooking bacon lately on the Weber Q100 outside right on the grill, works great. As far as the detector going off, if I push the test button, it stops beeping. No need to take out battery or cover with anything. As a matter of fact, the button has the words test/silence on it. Factory installed, not aftermarket.
2013 Sunseeker 2500 TSF
xgzx is offline   Reply With Quote
Old 06-11-2014, 04:10 PM   #38
B and B's Avatar
My smoke detector as supplied had a screw driven through the circuit board. The replacement one i bought goes off on humid like today while I am camping. Thinking of trying a different type, the dog goes crazy when it goes off!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-11-2014, 04:21 PM   #39
Like someone else, we use ours like the old dinner bell.
Old 07-09-2014, 05:48 PM   #40
masarost's Avatar
Same here. One of my dogs goes nuts and tries to hide under anything she can. Big dog, what a baby. So I always take out the battery before I start cooking.
2011 Coachmen 17RBX (Hybrid) Dual Axle
Camped 2013 - 20 days
Camped 2014 - 23 days
masarost is offline   Reply With Quote
