Old 10-17-2013, 05:01 PM   #1
chargeit2him's Avatar
Restricted roads/tunnels
Hubby and I were having a discussion about traveling roads that are restricted because of the propane in the RV's . Is there an app avaliable that shows which roads you can take or tunnels that are restricted ? Maybe on the google app store ?
Sandy
Ready to Explore !
chargeit2him is offline   Reply With Quote
Old 10-17-2013, 06:54 PM   #2
H2oski
I don't think your going to find an US app. Hwys and roads will change with construction projects. You may want to check the states DOT web page, they should have any restrictions on their state web site.
I have never found a bridge or tunnel on the east coast that had a NO propane restriction. I've had to turn the propane off prior to entering the tunnel before. Usually the attendant ask, and I tell them it's off. (I know, I know)
Good luck and safe travels.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 10-17-2013, 07:28 PM   #3
lswartz's Avatar
95 & 895 through Baltimore both have restrictions.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 10-17-2013, 08:08 PM   #4
Thanks for the replies
we will check things out
Sandy
Ready to Explore !
Old 10-17-2013, 08:10 PM   #5
Fulltime family RVer
Yeah- I don't know of any apps. I think there are low clearances point files that can be loaded into your GPS. But- I don't know if it includes anything about propane restrictions.
ependydad is online now   Reply With Quote
Old 10-18-2013, 04:01 PM   #6
Thanks for the replys I did know about the 2 tunnels under the harbor in baltimore and about the ones in New York. Did find out that as long as the tanks are off it is ok for the tunnels on the Pa Turnpike's
Ready to Explore !
Old 10-18-2013, 04:06 PM   #7
I never knew there were restrictions of any sort with propane in the PA Turnpike tunnels. Have been through them more than once without turning anything off.
Old 10-18-2013, 04:56 PM   #8
This is a E-mail I recevied from PenDot
Thank you for taking the time to contact the Pennsylvania Turnpike Commission.
You are okay to go thru the tunnels, just make sure your tank is turned off.
Sincerely,
Lori Mateer
1-800-331-3414
717-939-9551 ext. 5830.
Hours are Monday through Friday, 8:30 A.M. to 4:30 P.M
Ready to Explore !
Old 10-18-2013, 05:20 PM   #9
Funny- I just emailed them after looking on their site with no details about it. Thanks for sharing it.
Old 10-18-2013, 05:33 PM   #10
phat phrog stunt crew
if in doubt, call the state police of the states you wish to travel thru. they will direct you to who you need to talk to. keep in mind that any fine given to you for disobeying a hazmat route signage will NOT be cheap.
dwaynerz is offline   Reply With Quote
