Old 01-13-2019, 11:35 AM   #1
Stock outdoor grill review
My 2608 came with the grill pictured below. I've had outdoor grills before and was never impressed and frankly didn't use them as I felt the grill mount left the grill too close to the camper.
Fast forward to this one and I must say, for a cheap grill, this one has all the bases covered.
The mount moves the grill out and away from the side of the camper. I grilled two steaks last night and checked the sidewall several times. The gap between the grill and the wall is far enough and the wall stayed cold.
The steaks turned out perfect.
The propane hookup is convenient and easy to connect. I've carried 1lb containers and 20lb tanks for other grills in the past, but really didn't want to get into that again. This is so much easier.
Anyone else use their factory grill?
2rad4u is offline   Reply With Quote
Old 01-13-2019, 11:41 AM   #2
SecretSquirrel's Avatar
Yep. Same exact one that came with the FW in my sig. Works just fine. Small and easy to store. Only used it a couple of times though.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is online now   Reply With Quote
door
