Old 03-20-2017, 05:24 PM   #11
DustyRoads's Avatar
Last year my cable dragged on the ground and shorted out. I cut out bad section and spliced back together with waterproof connectors. Very easy to do just take your time.
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
Old 03-20-2017, 05:55 PM   #12
I've seen several cables where someone 'thought' that someone else had vandalized the 7 wire cable but as mentioned earlier, it was actually cut by being pinched on some part of the trailer or hitch area.
Make sure once you fix the cord that it is routed correctly in the event of a sharp turning situation.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 03-20-2017, 06:04 PM   #13
dmchapman's Avatar
Originally Posted by pdqparalegal1 View Post
I have had two partially cut cables. Not vandalism---I turned to sharp. Replacements re found at Tractor Supply or most other farm, trailer, Harbor Freight type places. Open your junctiion box and take good pictures. One wire at a time.
Last Summer I was trying to back into a spot at Half Moon Bay, CA. The angle was backward for the one way traffic lane. The sharp angle cut my cord same as yours. Also blew several fuses on the truck and the circuit breaker on the trailer. I used crimp type butt splices as a temporary fix and later sealed the repair with epoxy. Looks terrible but still works. I may not buy the new cord.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 03-20-2017, 08:34 PM   #14
Personally I would solder all the ends before I put it in the box AND DO NOT use connectors,,,,Solder and tape all connections!!!!!!Much better and safer......
Jim in Halifax is offline   Reply With Quote
mold, trailer
