Old 05-03-2012, 08:20 AM   #1
Brand New 2008 Surveyor SV-255RS
I found a 2008 Surveyor SV-255RS on a lot that is brand new. It was bought from the finance company that provides their floor plan, and was originally from a dealer that went out of business. There is a 1 year warranty, and the price is under $13K. What should I look for on this unit, and is there any reason I should not do this?
Thanks!
Magnetic is offline   Reply With Quote
Old 05-03-2012, 09:13 AM   #2
pbrackney's Avatar
Sounds like a great deal! It has been sitting outside for several years so check on the following:
All caulking seals on roof, around vents, antenna, sky lights,
All seams around windows and anything else that would have caulking
Make sure rubber roof is clean
Make sure outside vents are clear from insects, bees, nests, etc... Especially in furnace and hot water heater
Door seals around main door, storage doors, and slide outs are in good shape and clean
Jacks are well lubricated and not rusted
All appliances work and plumbing does not leak.
Of course there are PDI lists that you can use. Here is one that may be helpful for your walkthrough.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 05-03-2012, 10:29 AM   #3
acadianbob's Avatar
Pbrackney; good thoughts!!
We have the slightly smaller 235RKS and love it. If problem free, that is a great buy. Go for it!!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-03-2012, 11:12 AM   #4
Triguy's Avatar
Your situation is a little unique in that this trailer might have been sitting unused for 5 years (A 2008 could easily have been manufactured in Q1 2007).
In general, just plan to work everything from locks to lights, all switches, appliances, entertainment stuff and ALL systems (do this on battery and also on shore power).
Most importantly, check the roof, ceiling, walls and floors. I would be very reluctant to buy it if there are soft spots, delamination, signs of leaks, etc. Unless you want a project.
Pay attention to the tire date. Those may need to be replaced immediately.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-04-2012, 08:19 AM   #5
I'm pulling the trigger! Thanks for all the info and advice. I plan to do a complete inspection and PDI before signing any paperwork. I also informed the dealer that any tires over or near 6 years old would have to be replaced. We'll see how it goes!
P.s. They only install eaz-lift WD hitches there. Should I buy an Andersen or equal-i-zer and try to install it myself? I have plenty of tools and an area to work on it at home, but how would I get it home to install it? I really don't want to have to install it on the dealer's lot...
Old 05-04-2012, 08:28 AM   #6
acadianbob's Avatar
Most any brand WD hitch works for WD. But there are differences in how they handle anti-sway (if at all). I would not go with the cheaper friction bar approach. So see how that brand handles anti-sway.
If 2008, your rear slide may be a queen or a king. They changed kind of mid-year. Don't know if that makes any difference to you.
Good luck. Let us know what happens!
Old 05-04-2012, 08:33 AM   #7
Magnetic, you don't need a fancy hitch just to get it home. You can buy whatever hitch you like, then install it at your leisure.
But make sure you have a VERY good look at the roof caulking. If there is any serious cracking, and any potential for it to have leaked, be careful.
What part of the country are you located? If you are down south, the heat is a lot tougher on the roof.
Old 05-04-2012, 10:06 AM   #8
I have the 2006 model that I pull with my F150 and an EZ-Lift. It pulls really well in my opinion. Good luck and enjoy yourself.
rscastle is offline   Reply With Quote
Old 05-04-2012, 03:43 PM   #9
Why not hire an inspector to look it over before you buy. It will cost $250 to $300 but it may be worth it.
whj77372 is offline   Reply With Quote
Old 07-19-2012, 07:31 PM   #10
I use the E2 hitch on my 235 RKS. It is simple and works well.
Mr. Vic is offline   Reply With Quote
