Old 04-29-2016, 04:34 PM   #11
jhoppmann's Avatar
I bought a used 2012 F250 s.crew diesel 4x4 short bed last year. While I currently dont need that much truck, if I ever do a 5th wheel in the future I could definitely see running out of payload (yellow sticker is 2153). If possible I would go 350.
2015 Rockwood Mini-Lite 2306
2012 F-250 FX4 6.7 diesel
10k Equalizer Hitch
jhoppmann is offline   Reply With Quote
Old 04-29-2016, 04:38 PM   #12
Ford Idaho's Avatar
F350, eight foot bed, max out the tow package, fifth wheel/gooseneck prep. spray in bead liner.
Try to keep the bling to a minimum.
Old 04-29-2016, 04:48 PM   #13
Originally Posted by clr View Post
But a F250 SuperCrew cab can carry about 2700 pounds,
Or more. That is why my earlier post addressed trim level. My F250 Crew XLT is comfortably equipped and has a payload just shy of 3300 lbs.
Name:	IMG_2164 (Small).JPG
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 10 nights camped, + booked
Teamfour is offline   Reply With Quote
Old 04-29-2016, 04:54 PM   #14
Try towing a 15K fiver with your gasser.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-29-2016, 08:27 PM   #15
Kenny kustom's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
My V10 had some jam.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-29-2016, 08:43 PM   #16
As good as the V10 is 15K would be pushing it. My post was directed at the F250 6.2 / 3.73 truck with the much higher payload than the diesel. With 15K that truck is not an option. Heavy fiver + diesel = 350/3500 and a dually is not out of the question.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 04-29-2016, 08:56 PM   #17
Hold up a bit...F250 gas will have about 3,000 pounds of payload give or take, and an F250 diesel super crew will have just over 2k, possibly less with options...payload rating sticker. Weight of Diesel engine, extra battery etc.
F350 may cost you more on registration and insurance so you may want to check that...depends on state.
My buddy went from a Chevy 2500 gas to brand new diesel pulling a somewhat light fifth wheel, about 7 or 8 k. Said other than a smoother ride it wasn't near the difference he thought it would be but that was just one trip.
JLud is offline   Reply With Quote
Old 04-29-2016, 09:30 PM   #18
CaptnJohn's Avatar
My 2016 F250 6.7 is all I want/need. Bought it and researched 5ers with pin weight in a range. Did not want or need a "lite" or "1/2 ton towable" model. Wanted to stay under 38'.Far from every 5er would work but surprising how many will. Found this 35' with 3 slides and it fits the truck and us perfect. A little research to make the 5er fit the truck or the truck to fit the 5er is always required.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-30-2016, 10:50 AM   #19
blwnsmoke's Avatar
Yet you decided to get a camper that is rated more then your truck is rated for?
F250 has approximately 1,700 pounds of payload available before you are over your GVWR.. And your camper has a pin of 1,700lbs empty. You are overweight.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 04-30-2016, 10:54 AM   #20
blwnsmoke's Avatar
To the OP, get a F350. They will hold their value more then a F250 and you will have 1,500lbs more payload available to you.
A F250 weighs in around 8,200-8,400lbs which leaves you 1,600-1,800lbs. Factoring in family, 5th wheel hitch and anything you add to the camper in the front, that will most likely put you over.
My F350 has 3,100lbs of available payload. My kingpin weighs 2,200lbs, my hitch weighs 275lbs (slider) which leaves me about 600lbs for my wife, kids, grill, hoses and anything in the master bedroom.
f250
