Old 05-01-2016, 10:40 AM   #31
blwnsmoke's Avatar
Originally Posted by ferguson65 View Post
Please stop spewing this nonsense. The stickers are NOT accurate! Payload can only be calculated by weighing the truck and subtract that from GVWR.
To the OP, 350, long bed, factory 5th prep. I have a dually with airbags, so don't think going to a 350 gets you out of the woods on that one.
The 250 is the same as the 350 with the exception of the overload spring on the 350. If you get a camper package on the 250, you get the overload spring, so same as 350. The GVWR stays at 10k though, so you have to decide if that matters to you.
The F350 also has 4" blocks instead of 2" on the F250. There have been a few reported F250s that have come from the factory with 4" but no one can make any sense of it on why because it is not a package option.
blwnsmoke is offline   Reply With Quote
Old 05-01-2016, 12:10 PM   #32
blwnsmoke's Avatar
Originally Posted by CaptnJohn View Post
My F250 has a payload of 2467, far from 1700
You didn't answer the question I asked early. Do you have a Crew Cab, Supercab?? and are you 4x4?
You can see mine in my picture with 4x4 and it weighs 8,261 leaving me 3,239 best case scenario.
I have no clue how your truck can only weigh 7,533lbs with the diesel motor.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
Old 05-01-2016, 12:54 PM   #33
Witch Doctor's Avatar
I have a 250, just took it to the scales with full tank and hitch like came out with 7100, tag shows payload of 2775 on the door. My pin weight is 1760, my trailer weight fully loaded is 9180, it also has the heavy duty tow package super crew cab 6.5 bed. I have a long way to go before I run out of payload.
Sent from my SM-N920V using Tapatalk
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 05-01-2016, 12:57 PM   #34
Hit the button to quick my gross rear axle is rated at 6100
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-01-2016, 02:37 PM   #35
I have a Silverado 3500HD SRW diesel long bed and if I had to do it over I would have got a dually. I had a 2500HD diesel. A diesel gets a little better fuel mileage towing and now at least where I live costs less at the pump than gas, about 10 cents a gallon less
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 05-01-2016, 03:46 PM   #36
Kenny kustom's Avatar
X2...
I'm 3500 ccsb diesel.
Wish I would have gone dually long bed.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-01-2016, 05:53 PM   #37
I'm pulling our PDEK with an 08 GMC 3500 DRW. Dry your unit will be pushing 13600 lbs. Ours weighed in over 15200lbs ready to camp. You'll definitely want a 1 ton for your PDEK.
Sierra360PDEK is offline   Reply With Quote
Old 05-01-2016, 06:29 PM   #38
CaptnJohn's Avatar
You have a Platinum ~~ not sure about that but I was told to add 300# to an XLT for the Lariat pkg....
Some believe a 1 ton is needed to tow a popup too.... LOL!
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 05-01-2016, 07:13 PM   #39
ferguson65's Avatar
Most of F250's I see anymore have the 4" blocks. They were all "supposed" to have 4" blocks from 2013 on, but that clearly didn't happen. I agree there is no rhyme or reason to what trucks get them. So I'll change my statement to if you have the 4" blocks and a camper package it is identical to an F350, sans 11.5K GVWR sticker.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 05-01-2016, 07:15 PM   #40
ferguson65's Avatar
We are talking current model year trucks here.......................... Seeing your sig says 6.0, its not the latest generation. You may be great on payload on your truck, but the 2011 and up trucks are heavier.
2013 F350 dually
f250
