Old 06-25-2014, 07:17 AM   #1
oconomowoc's Avatar
Gas premium vs regular
Is there a difference in gas mileage that would offset the difference in price if I used premium gas instead of regular when hauling my TT?
2014 Shasta 21CK
Silverado 4X4
oconomowoc is offline   Reply With Quote
Old 06-25-2014, 07:28 AM   #2
Devilscreekw's Avatar
Look at your owner's manual and see the fuel recommendation. Premium fuel actually burns slower and cooler than 87, so you could actually be blowing out unburned fuel in your exhaust. My TV recommendation is for 87 octane so that's what I'm using. Premium could be even worse for the environment and lower your mileage.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 06-25-2014, 07:29 AM   #3
Kaadk's Avatar
I doubt it. I never had much of a difference running it in Mazda for highway driving so I doubt you'll probably end up paying more in the long run.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 06-25-2014, 07:30 AM   #4
fonzie's Avatar
Premium vs. Regular | Car Talk
Fonzie
Old 06-25-2014, 11:42 AM   #5
DF5.4's Avatar
Unless you are using a tuner that is programmed for premium it's not worth it. I use a tuner that has a heavy tow program (over 6000 lbs). It is setup for premium gas. That's when I fill up with it. Other than that I run regular and the 87 octane tune.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 06-25-2014, 11:48 AM   #6
TURBS's Avatar
I agree.
A good tuner can maximize mpg with high octane fuel.
Old 06-25-2014, 01:07 PM   #7
Guest
Correct. The engine's computer is PROGRAMMED to burn a certain octane level of fuel. Any other octane level will cost you efficiency. Therefore, a tuner is necessary. Do thorough research, though.
John4th is offline   Reply With Quote
Old 06-25-2014, 01:10 PM   #8
Rugged Brown's Avatar
How do you really know what you're pumping into your tanks?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 06-25-2014, 01:18 PM   #9
sail2liv's Avatar
I thought newer vehicle were able to adjust spark timing to accommodate what they are running on? Is the computer on new vehicle what you are calling a tuner?
Get rid of the barn door you are pulling and your gas mileage will go up......drag is the enemy along with speed.....as speed increases so does drag-
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 06-25-2014, 01:45 PM   #10
TURBS's Avatar
They do -ish
A good tuner can maximize fuel economy better tho.
gas
