Old 05-07-2019, 08:28 AM   #1
Generator advice
Hi Everyone!
New to the forum and have a questionable question about generators.
Just purchased a 2019 Mini Lite and wonder what generator to purchase. We most likely will be running air conditioner, TV and fridge at the same time. A/C is 11,000 BTU's. Would like a generator around $500.00 give or take.
Also, any advice on gen. use?
Thanks!
griffibaby is offline   Reply With Quote
Old 05-07-2019, 08:57 AM   #2
Hi griffibaby, welcome to the forum, I see it is your first post.
To new-comers, we often suggest a forum search for your question and generator advice is an often talked about topic with thousands of threads/posts.
Do a forum search (such as best generator) and you'll have days of reading.
You'll find plenty of folks posting THEIR opinion on what THEY think is best.
Do your homework and make YOUR decision based on what YOU feel is best.
If you plan to use the generator anywhere other than private land where no one else is around, be sure to purchase an INVERTER type generator, as the open frame/contractor type generators are TOO LOUD for campground use.
A $500 dollar budget will likely only get you an open frame/contractor type generator so again, in a campground, it will not be appropriate.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 05-07-2019, 12:21 PM   #3
Might also get him close to a Harbor Freight Predator unit, if he has coupons and is willing to throw another two hundred bucks or so into the purchase.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-07-2019, 02:49 PM   #4
bikendan's Avatar
Originally Posted by griffibaby View Post
Hi Everyone!
Thanks!
I doubt that the a/c is 11k btu. Should be at least 13.5k btu.
You usually only find 11k in super small trailers.
Unless you buy used, you won't find a capable new generator for only $500.
Only if you installed a Micro Air Micro Air unit, could run the a/c with a 2000w inverter generator for $500.
Don't need to run the fridge on electric. Switch it over to propane, while you run the a/c and tv.
Lastly, if you are going to run the generator in a campground, PLEASE get a quality INVERTER generator.
Any cheap open-frame contractor-style generator will exceed campground noise rules.
Equalizer WDH
Old 05-07-2019, 03:03 PM   #5
My 2000 W inverter (Generac) will not pull my 13.5 AC. Very comparable to Honda in test and I have been please with it for 3 years or so. I knew going in that we would not be able to do AC but that suited our mountain BD'ing and if too warm we go to full hook up site. The 2000 is a bit over your budget # and the Honda is even higher.
gbaldwin is offline   Reply With Quote
Old 05-16-2019, 03:17 PM   #6
Noob
Champion makes some great generators at great prices. You could spend a little bit more and get two of these inverter generators and run them in parallel - plenty of power to run the AC. Click image for larger version
Flywithlloyd is offline   Reply With Quote
Old 05-23-2019, 02:37 PM   #7
Generator advice
I run a Boliy 3000watt digital inverter electric start generator, runs everything in TT works great.Stole it at an auction brand new (still had the plastic on the gas cap never even fuelled) for $499 Cdn.
mulher is offline   Reply With Quote
Old 05-23-2019, 02:54 PM   #8
PPST Wannabe
kenandterry's Avatar
Cheapest isnít the biggest concern. If itís incredibly noisy for the price, others will shut it down and you still wonít have power for dry camping.
Just sayin.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-23-2019, 07:21 PM   #9
Noob
Griffi - come camping with me at some motorcycle rallies. You can run a cheap contractor generator all night long, and it still won't be he loudest thing around.
Old 06-18-2019, 07:26 PM   #10
https://www.costco.com/Firman-Power-...100367440.html
nitis is offline   Reply With Quote
Old 06-18-2019, 07:34 PM   #11
frank4711's Avatar
Get it .... love it ...
Frank & Cindy *** Rockwood 8288WS Ultra Lite 5th wheel *** 2019 Ram 3500 Cummins SRW 4x4 8' bed *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.73 axle *** Goodyear Endurance *** 44 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 06-22-2019, 04:47 PM   #12
updhaul's Avatar
Generac 3500 inverter
Generac has a recent addition with a 3500 inverter/generator with what should be enough power but closer to 630-700. I have heard it run on the back of a pick-up tailgate with the cap on and it was quiet there. It was only done briefly for noise demonstration. The 80lb weight makes it still light enough to be picked up. Not perfect but there are accommodations in price range with a dealer network.
updhaul is offline   Reply With Quote
Old 06-26-2019, 01:38 PM   #13
New Champion Generator
Just picked up a Champion 3400 Dual Fuel for boondocking. Best investment Iíve made for the Toy Hauler to date. Work flawlessly right out of the box on either Gas or Propane. Dry camping for a week and no issues with power.
ccontois is offline   Reply With Quote
Old 06-26-2019, 02:17 PM   #14
bikendan's Avatar
The Champion 3500w inverter generator is half the price of the Generac and has wheels.
The only advantages the Generac has is it's a little quieter and lighter.
No sure if that's worth twice the money.
Equalizer WDH
generator
