Old 08-14-2010, 06:28 PM   #1
Generators
We will be traveling from Florida to Arizona in a few months and plan to purchase a generator, but have no idea what will work best for our 25RL Wildcat fifth wheel. Any recommendations?
Tsunami1 is offline   Reply With Quote
Old 08-14-2010, 06:39 PM   #2
I'm in the process of buying a 3000W Honda generator. It'll run my AC & that's all that matters. They make 2 3000W inverter models if you're running any electronics. One is larger but has electric start. The "Handi" model, is manual start, but lighter.
You'll get a lot of replies about buying the cheap (albeit noisy) Chinese generators, but your CG neighbours will be chasing you w/ pitchforks when fire it up.
2017 Chevrolet K2500HD
2009 Rockwood 2106 Mini-Lite
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-14-2010, 06:49 PM   #3
NWJeeper's Avatar
Be VERY careful to check the specs on anything you are looking at. The Honda 3000 generators will run an AC no problem but not all 3000w generators are created equal. The cheapo ones will state that they are 3000 or 3500w but that is usually "surge" and the actual continuous run rating is 2500w which won't run an AC. This is the trap people fall into with buying cheap, you get what you pay for. Just because it says "3000w" on the outside of the box doesn't mean it is. Spend the money up front for a unit that will last you years to come and as the previous poster stated won't get the " CG neighbours chasing you w/ pitchforks when fire it up."
Honda and Yamaha are two names you just cannot go wrong with and they are worth the price.
Ed & Wendy
www.nwjeepn.com
Old 08-14-2010, 06:54 PM   #4
X2 on what Jeeper said.
Also, when you buy a Honda or Yamaha, you have easy access to service should you need it. The "other" generators are basically disposable. Most are sold @ auto parts or hardware stores that have no service dept'. Try finding a service center for your $300 3000W Feng Shui generator.
Old 08-14-2010, 07:03 PM   #5
NWJeeper's Avatar
Feng Shui Generator
Now that's funny right there, I don't care who yar.....
Ed & Wendy
www.nwjeepn.com
Old 08-14-2010, 09:12 PM   #6
Wanna Be Camper
SaskCampers's Avatar
EU3000is Honda all the way. It has better specs than the ligtweight 3000 and costs less. It only weighs 132lbs Ha Ha which in a locked truck box makes it a multi person job to steal it, that is of course after they break the grade 8 inch and one half linked chain.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 08-14-2010, 09:59 PM   #7
UHHH it is not only the elcheapo generators that list their ratings unrealistically high. ALL generators are listed at the maximum or surge power, not the running watts. That includes Honda and Yamaha. BTY my Yamaha 2800I starts and runs my 15K BTU AC unit just fine. So it is not always a matter of size but how many amps can it produce and for how long when it comes to starting an AC unit. But the OP did not indicate what he wants to run with this generator. In the probably 20 years of RVing with a generator I have only used my generator to run the AC once. The rest of the time I use it to supplement charge my batteries and when DW washes her hair I will fire it up so she can use the hair dryer. So in reality the first question someone should ask is What? Not how big he must buy.
Old 08-14-2010, 10:33 PM   #8
First question I have is why do you think you really need a generator?
You plan on parking in the Walmart parking lots?
Second part is a 3,000 watt Honda will be what you want. Even though they are waaayyyy over priced.
Electrical 101
P = Watts
I= Electrical Amps
E= Voltage
P = I x E
Normal Power
15 amps x 120 volts = 1,800 watts
20 amps x 120 volts = 2,400 watts
25 amps x 120 volts = 3,000 watts
LOW VOLATAGE in campground
If voltage is low see what happens.
Wattage stays the same , voltage drops and amps increase in opposite proprtion to voltage
P/E =I
16.36 amps x 110 volts = 1,800 watts
21.81 amps x 110 volts = 2,400 watts
27.27 amps x 110 volts = 3,000 watts
This is the main reason many circuit breakers trip
Old 08-15-2010, 05:40 AM   #9
Thank you all for your input! Who knows, we may end up in a Walmart parking lot or two along the way, we're just trying to be prepared for the long journey!
Old 08-15-2010, 08:26 AM   #10
Tsunami, You really need to determine what you actually want this generator to run. Figure that out and then go shopping. Unless of course you like spending money.
Old 08-15-2010, 10:51 AM   #11
Honda 3000 with a wireless remote starter and live will be good
Mark & Connie
2006 28RK Wildcat / 2006 Chevy CC 4x4 Diesel / 6 SPD Allison / RBW Slider
Pioneer in-dash navigation / Firestone airbags with in-cab controls /Prodigy Brake Controler / Honda EU3000 with wireless remote starter
rdsknfn_57 is offline   Reply With Quote
Old 08-15-2010, 10:51 AM   #12
NWJeeper's Avatar
The fact remains however that there are a lot of generators out there that claim to be "35000w" generators that actually only have a 2500W continuous run. The fact also remains that 100's if not 1000's of RVrs use the Honda 3000 to power thier AC.
No the OP didn't state he was running the AC with the generator but that was more or less implied by the fact that he stated he would be spending his time in Florida and Arizona, two places that get very very hot. If he had said he was going to spend all his time in International Falls MN then we would not have made that assumption.
It also comes down to the fact that despite the AC the converter/charger is always plugged in and depending on how far down the batteries are can draw quite a load to charge in the beginning. Using a generator that is too small will not only be bad for the generator but the AC unit as well. HVAC is very sensitive to low voltage/amperage issues. I would not want to take the chance of burning up either unit by going with less than a 3000w continuous generator and is also the reason why you will NEVER see less than a 3000W generator on motorhomes equipped with AC. Typically they are Onan 4KW gensets.
Ed & Wendy
www.nwjeepn.com
Old 08-15-2010, 10:53 AM   #13
We own rv's of course we like spending money. Some are sadistic enough to own rv's and boats !!
2011 Sierra 35 Loft TreeHouse
2006 Dodge 3500
Better Photo
Mowat is offline   Reply With Quote
Old 08-15-2010, 11:02 AM   #14
NWJeeper's Avatar
Make that two of us. And at least one of us here also has motorcycles and an airplane to boot. Well, to be honest I would have a plane too if I could justify it. That must make me really sadistic...
Ed & Wendy
www.nwjeepn.com
Old 08-15-2010, 12:02 PM   #15
Herk7769's Avatar
Yamaha with remote start
Yamaha EF30iSEB Propane Natural Gas Generators
I love mine. It lives in my pickup's bed. Runs on gas or propane.
Pricey, but I can start it without getting out of bed when quite hours are over and roll over.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-15-2010, 12:06 PM   #16
bikendan's Avatar
my vote is for a pair of Honda or Yamaha 2000 inverter models. with a parallel kit you can have 4000w available or just use the one for everything except the a/c. and they only weigh about 50lbs. each.
Old 08-15-2010, 12:59 PM   #17
NWJeeper's Avatar
Great Plan!
Ed & Wendy
www.nwjeepn.com
Old 08-15-2010, 01:15 PM   #18
Herk7769's Avatar
Last year at Sigsbee NAS, 98% of the campers used this arrangement. They were very happy campers.
An additional feature is two is better than one if your generator breaks down. There is a company that makes a fuel rig that will refuel both genterators from a single 5 gallon tank automatically.
I looked at that option as well.
Old 08-15-2010, 02:09 PM   #19
CLASS "A" Senior Member
cfsoistman's Avatar
Whatever Generator you decide on I'd be sure to have the Maximum Wattage so if you want to run just about everything you'll be set. You never know when a storm may take out your home power and you'll take up residence in your RV until the power comes back on which may be days. Just another thing to consider.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-23-2010, 03:27 PM   #20
acadianbob's Avatar
X2. Better to get two 2,000s than one 3,000. And for everyone's camping pleasure, make sure you get quiet generators instead of the cheap construction grade units that will wake the dead.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
