08-21-2018, 09:59 PM
Is this TT still worth purchasing?
Found a 2007 Cherokee 28a+ that meets our needs and is a fair deal. We are new to TTs and RVs, and want to do some family trips while we have the opportunity in the next two years. Although new to RVs, we have been researching and searching for two years.
The owners have experience and have had the TT for 10 years. They are very nice, and very helpful and the type of seller we were looking for. The deal was struck, and I went to pay when the owners realized they forgot something. They recently discovered a 1 ft x 6 in soft spot in the bedroom floor. At the owner’s suggestion, we paused the deal to have the issue looked at.
Turns out there was a slide out leak through old caulk that went unnoticed, and now the floor under the slide out is being replaced.
I have heard not to touch a TT with a leak, and this is why I’m posting. Otherwise, the deal looks solid and the issue will be fixed. What would you do?
Thank you to everyone who takes the time to read my long post and reply.
Cheers
08-21-2018, 10:33 PM
RV There Yet?
I was going to start by saying be warry of someone passing on their problems to you, the new buyer. but that is not the case here. your seller seems to actually care about the rig and your satisfaction of the sale as well, which sadly is very rare these days. I read about leaks, especially slide leaks, on here almost daily. it would seem that if the affected wood is replaced properly, leak sealed an other damage repaired and inspected to your satisfaction, I would take the deal and probably not think twice about it.
08-21-2018, 10:37 PM
Look closely down the sides for delamination. Bubbles in the siding.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
08-21-2018, 11:03 PM
I would want to monitor the repair and see how bad the damage was once tanken apart. The damage most likely will be much larger. I definitely would give the current owners credit for being up front about the damage. The only rv's that do not leak to some degree are ones that have not left the factory building.
08-21-2018, 11:17 PM
Coach
I agree the owners sound pretty genuine. That being said, it is 11-12 years old now. Give it a thorough look over. Even honest people can miss things. Take a good look at the roof. Is the caulking kept up or dry and cracked? That goes for any caulking as well, but especially the roof. Check around windows, door seals, etc. If everything is within your expectations, and the repair is completed to your satisfaction, I'd say pull the trigger. If anything about it makes you a little leery, walk away.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
08-22-2018, 01:16 PM
Also a lot of campgrounds don't want trailers over ten years old.
08-22-2018, 01:23 PM
usually the 10 year rule is for seasonals.. it sounds like they are going to be transients. so the age should not be a concern
08-22-2018, 01:26 PM
Those aren't campgrounds, they are higher end RV parks.
I don't consider those to be campgrounds.
Equalizer WDH
08-22-2018, 01:56 PM
Buying a camper several years old that has never leaked anywhere would be a rare find. Most do what the owners are doing, finding and repairing the leak, then repairing the damage. I would purchase if everything else checked out.
08-22-2018, 02:53 PM
Why not pay a professional to do a thorough exam as to the condition of that trailer before you buy?
-Rich
08-22-2018, 03:32 PM
Lacey's Spring, AL
our very first ‘camper’, had a leak above the living room slide out. It was a ‘13 Blackwood 40’ bunkhouse - and the owner had just experienced a storm which brought down a small limb, punching a small hole in the topper and slide roof.
the owner was having it repaired, prior to our picking it up, even though we had already struck a deal knowing that it was there.
great coach, and CW(yes! CW!) did a fine job on the repairs : )
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
08-22-2018, 07:24 PM
Just to clarify, we are tent campers trying RV CAMPING. The concept of an RV resort is something I just learned about, and have a difficult time understanding. We camp to get out in nature and away from the hustle and bustle and crowds of people. Since we are looking for a rustic experience, I don’t think the age of the TT will be a problem. Oddly enough, I’ve seen 3 year old TTS that looked worse than this one.
08-22-2018, 07:47 PM
I would still get it if:
1. Its a really good deal to start with.
2. Once the repairs are done, there are no soft spots and all checks out OK.
3. Once its yours, you plan to store it underneath a carport or something similar so everyday rain can not get to it.
A "no" to any of those three, I would not.
08-22-2018, 09:46 PM
Water leaks are an RV's worst nightmare. Thread carefully. As in anything used it's always buyer beware.
08-23-2018, 09:58 AM
Leaks cost time and lots of money, if the floor needs to be replaced surely one or all walls need be checked also. Been there, the whole back wall had to be replaced, dealer submitted 5K bill to mfg. Would image slide would be more expensive. Anyone who says leaks are common doesn't do preventive maintenance or has money to burn.
DJsFolly
08-23-2018, 10:03 AM
Gustafson
Guess I don't frequent very high end campgrounds because I've been camping my whole life and never heard this.
2013 GMC Sierra
2014 Rockwood Signature Ultra Lite 8325SS
08-24-2018, 09:19 AM
I've heard of it from a few different CGs, not just the high-end ones.
It's usually something in the seasonal contract that you have to sign but enforcement can vary. If your rig is in good shape they'll usually let it slide even if it's past the 10-year mark.
They just don't want some old, beat-up, ugly trailer sitting on a seasonal spot. But they can't put that specific wording into their contracts. So they use 10 years as a cut-off.
09-23-2018, 08:35 PM
Thanks for the advice!
Follow up. I always like it when the OP lets everyone know how an issue worked out, so I’m back. Unfortunately, the repairs were not to our satisfaction and we passed on this unit.
09-23-2018, 09:32 PM
Thanks for letting us know. It is the time that rvs go on sale, so hoping you find another rv.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
10-04-2018, 06:05 PM
We used to own a campground and this 10 year rule is very very common . It rarely applies to short stays . Usually long term or seasonal stays . Very Very common thru out the entire USA .
