Old 10-12-2010, 10:25 AM   #1
LED Light Panel Question: Good or Bad?
Hi All,.
I'm looking to buy some of farmerseller's (Hong Kong) 24 LED ($6.99) and 36 LED ($8.99) panels that are mentioned on other threads. It looks like NWJeeper and some others are using these.
How well are these LED panels holding up? Are they flickering and burning out prematurely or do they last?
I am using some 1156 LED bulbs that didn't last long at all so now I'm wary about "cheap" LEDs. But I do need to replace the ones over my stove and kitchen table that are burning out and these LED panels look good. But what kind of life are they giving? Price isn't bad, esp with free shipping, and I do need the power savings that LEDs typically give.
Thanks!
Paul Stamser is offline   Reply With Quote
Old 10-12-2010, 11:10 AM   #2
NWJeeper's Avatar
Out of the 10 or 12 panels I have bought I have one that has about 4 of the LED segments that will flicker a bit if left on too long. It is mounted in a light I don't use much so it hasn't been a big issue to me. Overall we are extremely happy with the LEDs and they sure are a lot easier on your batteries. I did find that the wiring will sometimes be reversed meaning that there is a pigtail on the light card that plugs into one of 3 adapters that come with the lights for use in different types of light fixtures. When the two are plugged in (it can only plug in one way) sometimes the black and red wires don't line up. Don't worry about it. When plugging into a wedge base socket it doesn't matter, they are reversible. If the light doesn't work one way, unplug the wedge from the socket, reverse it and plug back in.
We love ours.
Ed & Wendy
www.nwjeepn.com
Old 10-12-2010, 12:36 PM   #3
NWJeeper:
They sound like they are worth a try.
Do you use both 24 & 36 LED types or just one? I may get both to test them.
Do you know how much power (amps/watts) they use?
How many hours have you put on yours so far? With my cheap LED bulbs I used them for about a year or more before they began to burn out. The super-long life claim for LEDs isn't always true. I've had incandescent auto bulbs last for many years.
Right now I'm using 1156/bayonet type bases. But I'll probably just wire the LEDs directly into the circuit because I doubt they come with bayonet type adapters, or do they?
I'm excited about finding these (thanks to you). I also see that farmerseller also has some 1156 types but I'm guessing the panels might cast a better light pattern for over a stove or kitchen table. I will probably go with the panels.
Thanks!
Old 10-12-2010, 06:39 PM   #4
kz08h5's Avatar
I have tried both the 24 and 36 LED versions from farmerseller. I have not had any problem with them I replaced both 921 wedge bulbs with each to see if I liked them. For over the sink the 36 LED version is great and in fact I think does a better job than the incandescents. In my hallway the 24 version was not enough and the 36 is barely enough light. You might want to look into a 48. I also tried warm whites from another Honk Kong vendor on ebay. They are too yellow. I will be trying a mix by putting on bright and one warm white into one fixture to see if things average out. I do like the LEDs for dry camping and will put up with a little less light to keep the battery gong longer. I need it for the furnace.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 10-12-2010, 08:21 PM   #5
NWJeeper's Avatar
Originally Posted by Paul Stamser View Post
NWJeeper:
Thanks!
I believe they are the 48 light units. They come with a wedge, festoon and bayonett adapter. Although the LEDs will last for upwards of 50,000 hours, many times with the cheaper units the individual elements come unsoldered or loose and begin to flicker. As I said, I've only had the one board do that, most all of them including the ones we use most are doing great. I have only had them in the rig for a few months.
I did try some of the Thunder GP bulbs redily available on Ebay as well and found them to be very unreliable, loosing many of the LEDs very quickly. I have since thrown out the two I bought to test as almost all the individual LEDs hand failed. I would not recommend the Thunder GPs. I had used them in my porch lights. Although expensive I have had a very good experience with the bulbs from Starlights for my porch lights.
As for power usage I did do a test and posted the results here comparing the incandescent to the LEDs Of course there is a huge difference. I will try and find that thread.
Ed & Wendy
www.nwjeepn.com
Old 10-12-2010, 08:24 PM   #6
NWJeeper's Avatar
I would be very intrested to hear how this works out for you and how you like it. Let us know if you try it.
Ed & Wendy
www.nwjeepn.com
Old 10-13-2010, 08:19 AM   #7
Wanna Be Camper
SaskCampers's Avatar
Ditto,
I would like to put some LEDs in our TT but I have yet to find an LED that I can stand the quality of light from to read by or work in the kitchen. Our unit came with a flourescent unit over the sink, but I am not sure of the consumption. So let us all know how this works out.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-13-2010, 10:29 AM   #8
Good info!
Thanks for the heads up on the Thunder GP LEDs -- I was looking at those too.
You'd think with the farmerseller 48s the power consumption might be getting high -- but maybe not. Maybe I'll get a couple of each (24, 36, & 48) just to test them. Possibly two 24s over slightly different areas would work better than one 48. Right now I have one 9 LED over my counter, one over my stove and one over my sink -- sort of like spotlights. These are the ones burning out. But the counter, stove, and sink are all in a line next to each other.
My main concern is battery drain. I can live with somewhat dim lights and weird color. LEDs are great if we can find some "cheap" ones that are durable over the long term. I have an amp meter in my system, so I'll be able to report back exactly what the power consumption is if I get these jobs.
FYI, I'm doing this in a cabin back in the woods with a PV solar panel system, a battery bank, and the place wired like a 12 volt motorcycle. I do have a small gas backup generator but I hate running it. So I just added a 135 watt solar panel to the system. I'm fanatical about small loads and energy conservation.
Old 10-14-2010, 04:04 PM   #9
kz08h5's Avatar
Trailer is at the dealer for some warranty work. When I get it back I will do the LED Bright and Warm mix and post my results. I have noticed there a lot of people don't like the LEDs due to the color of the light they put out. My wife hates them but.... I took them out after showing them to her. Then I started putting them in one light at a time over the summer. So far she has only said something about the fixture that has 2 x 36 Warm White LEDs installed. She just asked why that light was so yellow compared to the others. That is why I want to do the mix of the 2 types. She either doesn't see a real difference or is being nice and letting me have my way. Either way my power consumption is down for dry camping.
kz08h5
Old 10-17-2010, 01:40 PM   #10
Bought 4 of them...
Well, I ordered 4 LED from farmseller in Hong Kong: two 24 LEDs ($6.99 each) and two 36 LEDs ($8.99 each). If these work propertly I will probably order more. I'll see if these throw enough light before I order a 48 LED.
Thanks for the tip!
