Old 10-02-2017, 05:52 AM   #1
Slide Out Stabilizers - Yes or No?
Newbie question ... I've seen slide out stabilizers and am wondering if we should invest in some. We have a 394FKDS that is stationary at a campground, so we won't be moving it unless we replace it. Wondering if the stabilizers are worth the investment to give it a little extra support. Thanks in advance!
runmom1 is offline   Reply With Quote
Old 10-02-2017, 06:07 AM   #2
Only if you have the frame on blocks so if a tire goes down, you won't damage the slide.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 10-02-2017, 10:42 AM   #3
Enjoying Life
Most manufacturers say NO. If anything were to cause the trailer to lower or move for any reason, there goes your slide.
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!” - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is online now   Reply With Quote
Old 10-02-2017, 11:18 AM   #4
Thanks ... Quick note - there is a structure surrounding the TT, so it's basically got a big roof over it. Not sure if it would ever move or lower unless there was a big washout of any kind.
Old 10-02-2017, 11:38 AM   #5
A roof is fine and dandy but how about if a tire that goes flat?
It will drop several inches and if you have stabilizers under the slides it won't be pretty. That's why I said in my original post... if you have the frame up on blocks it won't matter if a tire goes flat, they will carry the load and not the tires so in that instance, slide stabilizers would be OK.
Under normal everyday towing circumstances, today's slides are meant to carry their loads without the use of stabilizers.
A rig set up at a seasonal site with blocking under the frame it would be OK but not necessary.
Old 10-02-2017, 01:27 PM   #6
MacDR's Avatar
X20 on No.. I once whitnessed the damage of a flat tire and slide stabizer..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 10-02-2017, 01:48 PM   #7
Abosolutly NO!!
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 10-02-2017, 01:59 PM   #8
bwodom's Avatar
So how do you stabilize the slide? Ours is not solid and we can feel the rig shake when we walk on that side or sit at the dinner table which is located on the slide. The stabilizers do help with that. Will the jacks not support any weight in case of a flat? I would think the flat would be gradual, not a blowout, while sitting still?
bwodom is offline   Reply With Quote
Old 10-02-2017, 02:04 PM   #9
We do have it on blocks ...
Sent from my VS995 using Forest River Forums mobile app
Old 10-02-2017, 02:29 PM   #10
Well there you go...
Old 10-02-2017, 02:38 PM   #11
Jacks or stabilizers?
Most rigs today come with stabilizers on the four corners.
They are not meant to support the weight of the entire trailer.
If a tire goes flat, (quickly or otherwise) the stabilizers will likely just bend under the pressure. And if you have a stabilizer under the slide when that happens... well who knows how far the slide might bend out of whack as well.
If you have jacks under the four corners then that may be different... providing the frame doesn't bend.
The ONLY time slide out stabilizers are recommended to be used is if the unit is set on multiple piers or blocks on the frame rail on both sides.
Old 10-02-2017, 08:59 PM   #12
For one brief shining moment I also thought of stabilizers. Hold up the slide out and everything would be nice and steady - BUT - the way most of these slide outs are designed, they are boxes that slide out and hook on the bottom edge of the side with the top and sides of the box pressed against the sidewall of the unit. If you put a stabilizer under those types of slide outs and have a movement in the trailer the stabilizers will exert a push up pressure on the slide out and push it into (or possibly through) the trailer roof! And that won't be covered by a warranty, either. Just don't do it. You will be out the money for the stabilizers and you may have to rebuild your trailer.
ProfChuck is offline   Reply With Quote
Old 10-19-2017, 06:36 PM   #13
I tried several things to improve the stability of my parked travel trailer Rockwood UL 2604. I ordered mine with scissor jacks vs electric because I was told they may do a better job with stability. I use 4 x 4 blocks under the jacks so they are not fully extended. Purchased the X chocks to go between the wheels and still was not satisfied. Friends told me about putting jacks under steps (and slides) etc. I saw at a campground a travel Trailer with pipe braces from the bottom of the jacks back to the frame. Looked like a good idea to me and I found a few companies that make such a product. I settled on the Steady Fast system because it was simple to use and easy to install (although not cheap) and very well made. On my trailer the results have been fantastic. I can say it got 95% of the movement out of the trailer. I am very satisfied with the results. I would guess the other brands work well with the same concept.
ID:	154555   Click image for larger version
ID:	154556   Click image for larger version
RockwoodUL2604 is offline   Reply With Quote
slide, slide out, stabilizers
