02-28-2012, 11:41 AM
Small Honeywell 800 watt Generator
I wonder what you can power with this. It's ultra portable and quiet. If you use Coupon Code: EMCNHHB83 you get free shipping. Anyone know if its a good deal?
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
02-28-2012, 11:49 AM
Not much power is it. I suppose you could charge your batteries and run lights.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
02-28-2012, 11:57 AM
Cheap enough. I see no decibel rating on it. I would be leary for that fact. There dosen't seem to be alot of good reviews on it from what I can see.
02-28-2012, 12:35 PM
Based on the Honeywell Brochure it looks like you would want the 1600watt or 2000watt version.
They indicate that they will charge a 12v battery the 800watt will not.
The single review on the above site indicates the unitis noisier than expected (but who knows what that 1 reviewer expected out of a 4-stroke engine)
Barney
2020 Salem Cruise Lite 241QBXL
2016 Ram 1500 Big Horn Eco-Diesel
Previous Trailer -> 2012 Rockwood Roo 233s
-> 1996 Jayco 1207
02-28-2012, 12:48 PM
Here is my take on generators that don't list the decibel rating and are marketed as quiet. Most are not.
02-28-2012, 03:19 PM
about all that it would be good for, on a RV, would be recharging the battery and powering some lights and water pump.
not enough to run a microwave.
the Honeywell 2000w was a disaster in returns because it had many issues.
RV.net has a huge Honeywell 2000 thread going.
and it was louder than other chinese made inverter generator.
02-28-2012, 03:31 PM
As others have said, I'd be leery of noise with no DB rating.
OTOH, you can run a 25 amp battery charger on about 300-400 watts so an
800 watt genny will easily charge batteries.
FYI,
Power in Watts = Amps times Volts
So 12 volts times 25 amp charger = 300 watts plus normal losses.
That's why I said 300 to 400 watts.
Still that's half the max output on that genny.
Peace!
Dan & Rita D
02-28-2012, 06:15 PM
Originally Posted by KyDan
FYI,
Is that a 12v charger or a 120?
02-28-2012, 08:13 PM
I bought a 3600 watt generator at Sams Club. It is not an inverted generator and it isnt as loud as a commercial generator for $320
If you run the A/C - you cant hear it running outside.
I do not plan on using it at a campground because most of the place I camp have Electric and Water - If I decide to run it at a campground I will most likely make some sort of a dog house for it to help reduce the noise
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
02-28-2012, 09:04 PM
You know I have a 4cycl Weed trimmer that broke at shaft. I wonder how hard it would be to make my own generator. hmmm
Ruben Zamora
02-29-2012, 04:42 PM
Watts don't care.
If you are charging a 12 Volt battery with a charger that has a max output
of 25 amps on the battery side my math is correct.
The charger would appear as a 300-400 watt load on the generator.
The generator would be putting out 120 volts at 300 watts (ignoring
losses) so it would be producing 120 volts at about 2.5 amps.
The charger would be converting the 120 volt AC to 12v DC and both would
still be about 300 watts.
Some generators have 12v outputs but they are typically limited to
10 amps or less.
It's faster and more efficient to use a charger plugged into the AC outlet
on the generator.
Peace!
Dan & Rita D
02-29-2012, 04:51 PM
I didn't phrase my question right I guess. I was trying to get the math to work right in my head. The way I see it a 25 amp charger would use 120 volts, not the 12 you had stated earlier. So, wouldn't a 25 amp 120v charger be using 3000 watts? not the 300 stated earlier?
02-29-2012, 10:31 PM
Converting Watts to Amps
The conversion of Watts to Amps at fixed voltage is governed by the equation Amps = Watts/Volts
For example 12 watts/12 volts = 1 amp
Converting Amps to Watts
The conversion of Amps to Watts at fixed voltage is governed by the equation Watts = Amps x Volts
For example 1 amp * 110 volts = 110 watts
Converting Watts to Volts
The conversion of Watts to Volts at fixed amperage is governed by the equation Volts = Watts/Amps
For example 100 watts/10 amps = 10 volts
Converting Volts to Watts
The conversion of Volts to Watts at fixed amperage is governed by the equation Watts = Amps x Volts
For example 1.5 amps * 12 volts = 18 watts
Converting Volts to Amps at fixed wattage
The conversion of Volts to Amps if the wattage is known is governed by the equations Amps = Watts/Volts
For example 120 watts/110 volts = 1.09 amps
Converting Amps to Volts at fixed wattage
The conversion of Amps to Volts if the wattage is know is governed by the equation Volts = Watts/Amps
For Example, 48 watts / 12 Amps = 4 Volts
Converting Volts to Amps at a fixed resistance
If you know the volts and the load of the resistance the amps are found by Ohm's law: Amps = Volts / Resistance
Converting Amps to Volts at fixed resistance
If you know the amps and the resistance Ohm's law becomes Volts = Amps * Resistance
02-29-2012, 10:49 PM
RubenZ hook a drill up to that Weed trimmer change the male plug to a female plug and you will get a low wattage genny.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
03-01-2012, 07:46 AM
OK you just have to look at it one side at a time....
The OUTPUT of the charger is 12 volts and 25 amps so 12 x 25 = 300 watts.
OR
On the INPUT side of the charger if you increase the volts by 10 times
to 120 volts you DEcrease the amps by the same factor of 10 and the
WATTS stay the same. 120 volts X 2.5 amps still = 300 watts.
The above example totally ignores heat losses in the charger as well as
the fact that a battery is usually charged at around 15 volts but my
statement still stands--
Even the smallest generator can power a 25 AMP OUTPUT battery charger.
The problem usually is the smallest cheapest generators are noisy.
Peace!
Dan & Rita D
03-01-2012, 10:43 AM
Check this out!! muddymuddymuddmann's Channel - YouTube
Ruben Zamora
