Old 02-28-2012, 10:41 AM   #1
RubenZ's Avatar
Small Honeywell 800 watt Generator
I wonder what you can power with this. It's ultra portable and quiet. If you use Coupon Code: EMCNHHB83 you get free shipping. Anyone know if its a good deal?
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 02-28-2012, 10:49 AM   #2
Malco's Avatar
Not much power is it. I suppose you could charge your batteries and run lights.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 02-28-2012, 10:57 AM   #3
Cheap enough. I see no decibel rating on it. I would be leary for that fact. There dosen't seem to be alot of good reviews on it from what I can see.
rkswyo is offline   Reply With Quote
Old 02-28-2012, 11:35 AM   #4
Barney1's Avatar
Based on the Honeywell Brochure it looks like you would want the 1600watt or 2000watt version.
They indicate that they will charge a 12v battery the 800watt will not.
The single review on the above site indicates the unitis noisier than expected (but who knows what that 1 reviewer expected out of a 4-stroke engine)
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 02-28-2012, 11:48 AM   #5
Here is my take on generators that don't list the decibel rating and are marketed as quiet. Most are not.
Old 02-28-2012, 02:19 PM   #6
bikendan's Avatar
about all that it would be good for, on a RV, would be recharging the battery and powering some lights and water pump.
not enough to run a microwave.
the Honeywell 2000w was a disaster in returns because it had many issues.
RV.net has a huge Honeywell 2000 thread going.
and it was louder than other chinese made inverter generator.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-28-2012, 02:31 PM   #7
KyDan's Avatar
As others have said, I'd be leery of noise with no DB rating.
OTOH, you can run a 25 amp battery charger on about 300-400 watts so an
800 watt genny will easily charge batteries.
FYI,
Power in Watts = Amps times Volts
So 12 volts times 25 amp charger = 300 watts plus normal losses.
That's why I said 300 to 400 watts.
Still that's half the max output on that genny.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-28-2012, 05:15 PM   #8
Titleguy's Avatar
Originally Posted by KyDan View Post
FYI,
Is that a 12v charger or a 120?
Titleguy is offline   Reply With Quote
Old 02-28-2012, 07:13 PM   #9
sherdep's Avatar
I bought a 3600 watt generator at Sams Club. It is not an inverted generator and it isnt as loud as a commercial generator for $320
If you run the A/C - you cant hear it running outside.
I do not plan on using it at a campground because most of the place I camp have Electric and Water - If I decide to run it at a campground I will most likely make some sort of a dog house for it to help reduce the noise
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-28-2012, 08:04 PM   #10
RubenZ's Avatar
You know I have a 4cycl Weed trimmer that broke at shaft. I wonder how hard it would be to make my own generator. hmmm
Ruben Zamora
