Old 07-13-2016, 05:06 PM   #11
WFD
Originally Posted by brewjaz View Post
I would use biodegradable, as I do in my RV and at home---Mrs. Meyers is very good.
I never have "gunk" build-up in my tanks (or pipes at home).....plus it's good for the environment.
Cracks me up when people claim to not have any build up in their grey and yes...some even say their black tanks...When was the last time you squeezed through the drain hole to go inspect the inside of your holding tank......Just cause the sensors appear to be working properly doesn't mean the soap you are using creates any more or less buildup than any other brand...just means maybe you are managing your tanks properly.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-13-2016, 05:11 PM   #12
BlissHunters's Avatar
Originally Posted by FordHauler View Post
Goat's milk soap huh! Easier to milk a goat than a grizzly? Ok,ok!
I believe that any soap you choose will do. We use Dawn for dishes.
I like to leave a little water in both tanks occasionally and add a cup of liquid tide, then as I drive to the next stop things get washed around and when I dump at the next stop and the tanks are cleaner. (That is only a bubble machine blowing from my roof vents.)
Yes, those pesky indicators work when and if they please. The shower is full of water honey, says the gray tank needs to be emptied. After a while you learn to listen to the black tank and know when it is ready to dump.
Travel safe
Thanks for the tips.
Our previously owned TT was well taken care of just want to continue not gunk things up.
Sent from my SCH-I545 using Tapatalk
BlissHunters is offline   Reply With Quote
Old 07-15-2016, 09:05 AM   #13
Google GEO method
The GEO method adds Calgon water softener to the black tank. Probably a good idea for the grey tank too. Our water here in NM is very hard. So hard that a small drip in the plumbing will fix itself with calcium buildup. Sweet.
mnoland30 is offline   Reply With Quote
Old 07-15-2016, 09:12 AM   #14
Here we don't have that issue but we won't be camping in the driveway for ever @ least I pray not.
Thanks !
