Old 03-02-2011, 04:24 PM   #11
camping
tentcamper1's Avatar
I used to use the gas can method to fill up and it worked great. About 3 years ago I got a great deal on a 15 gallon RV water tank and 12v pump at a surplus place that was closing its doors. It works great. This winter I got a 30 gallon tank and will set it up as soon as the weather gets warm. I went to the bigger tank because it was always 2 trips to fill the trailer.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 03-02-2011, 06:20 PM   #12
Send a message via Skype™ to scubieman
Pictures? And where you get it?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 03-02-2011, 07:38 PM   #13
camping
unfortunately I don't have any pictures and ever thing is put away until spring. the ebay link is a tank similar to mine, I went to the surplus store in Elkhart to get mine. I just ran a hose from the tank to the pump and then have an adapter on the output side that will allow me to hook up my water hose.
rv water tank items - Get great deals on eBay Motors, Everything Else items on eBay.com!
I used clips to attach the wire to the battery and this year will use a some type of plug so I don't have to take off the battery cover.
2010 V-Lite 30WRLTS
Old 03-09-2011, 12:20 PM   #14
kalik282's Avatar
I use a Half-moon style 48 gallon tank. (Sold for horse trailers...)
Half Moon Lay Down Water Caddy tank 48 Gal High Country Plastics
I comes with a standard garden hose connector & a shut-off valve. Fits in the truck and does not move around.
I hook the hose up to a 12V water pump from Harbor Freight Tools. 12 Volt Marine Utility Pump
I cut the alligator clips off and wired on a standard male 7 pin trailer connector. Now I just plug into the TV's trailer plug, and can pump the water from the tank as far as my hoses will reach!
Hope this gives you some ideas...
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 03-09-2011, 12:44 PM   #15
That is a darn good idea. I love how cheap the pump was. I may get one for furture use.
I found out that wife was not going for the idea of a water bladder. I called the place we were dry camping and they said there is places to get water. It sounds Like I will probably get two 5 gallon callopsable jugs for there. It will only take 6 trips to fill tank Unsure of distance to water.
Old 03-09-2011, 06:15 PM   #16
kalik282's Avatar
Scubie,
If you are close enough to a water spigot (that's not threaded) then maybe this would help. (I keep one in my kit of water hose "stuff")
Amazon.com: Camco 22484 RV Water Bandit: Automotive
John
John & Nicole
