Old 07-17-2016, 06:58 PM   #21
northstar1960's Avatar
Originally Posted by SeaDog View Post
Northstar 1960 You saw my post before I edited it I was not fast enough, That was not right on my part and I apologize.
Back at you . no problems . i know as well as you that tones get read into posts that are not really there . guess it depends on what mood we are in .
i'm just saying not all china tires are bombs . i use the Hercules brand . part of cooper tire . seems they make them in china . well 2 sets on my TV about 80,000 miles and never a issue or flat . now Hercules st e rated on my TH over 8000 miles and no issues . i do agree many cheap tires come out of china and this needs to be stopped . but there are some good tires also . weather marathon is as good as they used to be , i don't know never liked goodyear tires myself
northstar1960 is offline   Reply With Quote
Old 07-18-2016, 07:58 AM   #22
I try to tell people to get a TPMS that you trust and keep your tires checked. I can't see my tires in my rear view mirrors and I depend on my TPMS. You can't look at a tire and tell much about it unless it's flat, same way with kicking the tires. I'm sure that tires that come from China is a problem, they don't manufacturer tires in China because of the best labor, its because it's the cheapest place. Tires have be checked just like oil and fuel, maybe not as often but they need to be checked daily.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 07-18-2016, 12:08 PM   #23
have you ever tested your tpms to see how long it take to send signal to the monitor ? like taking off one of the sensors ? i wonder because i've heard it can take up to a couple mins . just wondering . also there are many brands out there from 29.99 to 599. do they al;l work the same or are some better then others . tire temp to me is not an option i would pay for just psi and the rapid loss of psi so one could pull over before damage is done
Old 07-18-2016, 12:26 PM   #24
SeaDog's Avatar
My system came from TST truck system technologies and can monitor up to 22 tires. It cost $200 + can't remember the actual cost. When the unit is first turned on, mine can take up to 5min to acquire all tires, after that it cycles thru the four tires in less then a minute. it has high/low pressure alarms (you set) and high temp factory set.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 07-18-2016, 01:10 PM   #25
Who Dares, Wins
doc73's Avatar
My tire minder alerts with in a second or so. When I unscrew the valve cap / sensor it alerts the drop in pressure before I can get the cap completely unscrewed.
Sent from my SM-G930V using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 07-18-2016, 01:20 PM   #26
that's the answer i was looking for . so it this the same with all tpms or just with a few ? i assume you have the tire minder brand?
Old 07-18-2016, 01:21 PM   #27
Who Dares, Wins
doc73's Avatar
Yes I do. I cannot speak to all brands only what mine does. It connects to all tires ad soon as it turns on.
2015 ChevyHD D-Max
2014 Greywolf 26DBH
Old 07-18-2016, 01:21 PM   #28
How long does it take to sense a rapid loss of psi ? just trying to get info on the models out there
Old 07-18-2016, 02:17 PM   #29
SeaDog's Avatar
it will alarm instantly at rapid loss. The only wait is when the monitor is first turned on.
Retired Navy
AF&AM of Idaho
Old 07-18-2016, 02:42 PM   #30
one more ? what brands are good and priced moderately . also how much room do you need on the stem . i have short metal stems on mine and not sure from looking at the sensors if they will fit with a short stem
tire, tires, trailer
