Old 07-31-2018, 06:47 AM   #1
TST507 Great $
After reading a number of comments on the Forum about TPMS I ordered the TST-507-FT from RVupgrades.com for $297. It has 4 cap, color monitor, repeater and free shipping. Going to go to Hot Springs Ar in a couple of weeks to try them out. Then in September going to go to Gulf Shores State Park for a week. This will be our first long trip about a 10 hr drive. Any advice for a newbie? They have 4 left.
I love this forum. The things I read on here are very helpful and enjoyable to read.
Ar-Newbee is offline   Reply With Quote
Old 07-31-2018, 08:59 PM   #2
dbledan's Avatar
Just keep an eye on sun side vs dark side as pressures and temps may vary. Not alarming unless you don't see things slowly change.
The one note I have is remove the sensors when in storage over the winter. It helps the batteries last longer. I leave them on all year but remove for winter slumber. Good luck!
dbledan is offline   Reply With Quote
Old 08-01-2018, 05:23 AM   #3
jd50i's Avatar
I pull my sensors off when not using, they are supposed to turn off when they don't sense pressure. I can also use them on my other trailers so the system is portable you just need to know if you need the repeater on another trailer or not.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-01-2018, 05:50 AM   #4
Thanks for the information. Do you have to reprogram them each time you put them back on?
Old 08-01-2018, 06:19 AM   #5
jd50i's Avatar
No, as long as you have marked them as to which one is left front, right front etc.
2014 Grey Wolf 21RR
Old 08-01-2018, 06:52 AM   #6
W5CI's Avatar
it sounds like you found a great deal. The TST507 works great. you will see a buildup of tire pressure of 10 to 20 lbs from my experience. More so on asphalt than concrete and the side in the sun will always run hotter. I have the color monitor and curious how you have it mounted. actually I haven't used the color monitor because I don't know how to mount it where it will stay on the dash. I still use the original monitor.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 08-02-2018, 05:53 AM   #7
Ií donít have it yet. Iím supposed to get it today August 2.
