Old 01-29-2016, 01:35 PM   #21
No mater what's on your truck you hit a moose all you do is take out its legs and the rest of it goes through your windshield. drive carefully.
j free is offline   Reply With Quote
Old 01-29-2016, 06:01 PM   #22
Stormrider151's Avatar
Most brush guards are nothing more than great places to hang a bunch of lights. Although that will help in identifying what's coming through the windshield before it gets there. Be safe.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 01-29-2016, 06:20 PM   #23
I had one on my jeep that got taken out by a minivan. Then upgraded to one that actually tied into the frame of my jeep, and it took a 50mph hit against a deer and barely budged. So not only is it how heavy duty the unit it is, but also how it is tied into the vehicle.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 01-30-2016, 06:43 AM   #24
A32Deuce's Avatar
Believe it or not, you need the type they use downunder. They work. Most up here are for show. Pre- Runner type might do the trick. The Aussy Roo- Bar works.
Sent from my DROID4 using Tapatalk
2012 SunSeeker 3100SS Toad-1962 Futura
A32Deuce is online now   Reply With Quote
Old 01-30-2016, 09:08 AM   #25
Originally Posted by Tim Rey View Post
Moose, elk and beer probably not much help.....
Drunk moose and elk are the worst.
johntaylor is offline   Reply With Quote
Old 01-31-2016, 11:40 AM   #26
guard
when I drove up built one used heavy screen wire. only thing you need to worry about are rocks from some one in front of you. when I went up in 1971 was no pavement. lot of fun driving. john
jayhawkjohnny is offline   Reply With Quote
Old 01-31-2016, 11:49 AM   #27
I Break Everything
mikel68's Avatar
We have motorhome now, but my truck has a Ranch Hand guard on the front. Saved my truck twice. I was rear ended in Houston. I was pushed into the car in front of me. I was stopped when I was hit. My guard put their trunk into their backseat. No damage to the front of the truck at all. Otherwise all those plastic lights, grills, hood, etc. would have been smashed. Second time, hit white tail deer crossing a road. Killed the doe only blood and hair on the Ranch Hand. Not one of those gigantic bumpers either. Just the guard.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 01-31-2016, 02:20 PM   #28
Made that trip 20 years ago. Not bad then, probably better now. I saw everything from cattle guards, I-beams with wire screen and 4x8 plywood across the front of TTs.
I only had headlight screens and hardware cloth for the radiator. No losses and no damage. Rocks are far more prevalent than wildlife.
Just drive during the daylight (pretty hard not to during the summer) and make sure your insurance is solid!
As cap'n Ron says, "If anything's going to happen, it'll happen out there!"
Relax and try not to over think it. It is an adventure and well worth it.
Ken & Cindy
TooLoose - WeTrek
04.5 CTD 2500 Dodge 6spd manual
2014 Flagstaff 8528ckws
elkabong is offline   Reply With Quote
Old 02-01-2016, 04:28 PM   #29
wuffwuff's Avatar
Just another note .... brush guards can interfere with the Airbag deployment.
It's Easy to take 'Liberty' for granted, When you have never had it taken from You!
wuffwuff is offline   Reply With Quote
Old 02-03-2016, 12:56 PM   #30
Make sure it's heavy duty materials used in the construction (I.E. Steel) otherwise when you hit a deer or elk (which is more likely then a cow) at high speeds it will mess up not only the guard, the guard will bend and fold into your vehicle front end usually taking out lights and radiator etc. a typical brush guard will not do do the trick...check out monsterbumpers.com as an example of what to have..there are lots of options on the Internet..
rpomeroy is offline   Reply With Quote
cat
