06-21-2013, 01:03 AM
2012 Micro Lite 21 FBRS
What alternatives are there for toilet tissue?
I have seen the toilet paper test on you tube, but I prefer to ask the pro's. Is there anything that would be safe to use in RV septic system besides the expensive stuff? TYIA
2012 Flagstaff Micro Lite 21 FBRS
06-21-2013, 04:36 AM
I performed my own tests and found that Angel Soft dissolves fairly quickly. I use Charmin at home but would not use in my camper. I've been using Angel Soft in my camper with no problems for almost 3 years. However, I also follow the geo method (do a search if you do not know what this is).
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
06-21-2013, 06:02 AM
Campfire Master
Members Mark from Sams Club breaks up real fast.
John
06-21-2013, 07:47 AM
We've been using Angel Soft for years with no problems. Just make sure you use plenty of water when flushing.
06-21-2013, 07:58 AM
Plenty of water is the key. I have used regular TP in a pinch (NEVER without a sewer connection) without issues; it just goes out with the rest of the junk.
I DO have a turboflush and use it for 10 minutes or so (and a clear elbow) to make sure it all fishes out.
Remember your RV tank is NOT a septic system. It is a holding tank. It is designed to fill up and be dumped. There should be no "biologic breakdown" going on in there (Except for the end of season total clean out where I use RV-Digest-It and a 72 hour soak to clean the walls and corners).
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-21-2013, 08:01 AM
Try Scott Toilet Tissue. One of my RV Assoc recommended it.
06-21-2013, 08:04 AM
Old Member
Herk,
You should consider writing a book on RVing with all the good tips thrown in!
Safe travels & enjoy the journey!
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
06-21-2013, 08:14 AM
daydreaming about camping
Originally Posted by mikey
Herk,
But then we would have to pay for all the advice we get for free now!!
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
06-21-2013, 08:19 AM
Herk,
Agreed. Or a video.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
06-21-2013, 08:52 AM
They used to use Sears Roebock catalogue pages, worked then! Any single ply (cheap) will work. Never had a (t)issue in over 20 ywears!
06-21-2013, 09:04 AM
Use Scott read label its septic and rv safe. We have been using this paper since the 60s for rv and home.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
06-21-2013, 09:08 AM
Why not use a Walmart bag? Ours hangs on the bathtub water knob. We use whatever brand we want and use as much as we want
And we always make sure to put the "shiny side" facedown in the bag.
Change out the bag as often as needed.
You could add a toilet washer hose deal and use it as a bidet.
2016 Ford F150 Platinum
2013 Coachmen Freedom Express 233RBS
Prior: Jayco Pop Up, Shasta Bunkhouse, Rockwood 2560G Pop Up
06-21-2013, 09:16 AM
Been there; Done That.
http://www.forestriverforums.com/for...c-v-15261.html
WORKS GREAT. DW and I both love it.
EASY bowl cleanup with minimal water usage.
Do not use the built in tap on the flush valve. Make your own so full pressure is available with the flush valve closed. If you use the built in hose "bib", you have to keep the flush open to get water pressure and it is split between the bowl wash and the pressure sprayer.
06-21-2013, 09:23 AM
Graduate Member
Charmin. No problems, just listen to Herk and use plenty of water. ALL toilet paper breaks down in water.
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days 2012 - 26 days
