Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Community Forums > Dollars & Cents
Old 01-25-2012, 11:41 PM   #51
Has anyone heard anything about these units:
NEW Ryobi Portable 2000 Watt Superquiet Generator L@@K | eBay
Ryobi is a pretty common power tool brand, so I'm not worried about that, and it seems a little more price competitive than Honda and Yamaha...thoughts?
2009 Salem LA 292fkds (new toy)
2011 Dodge Ram 2500 Crew Cab 4X4 CTD (new tow rig)
2006 VW Jetta TDI (daily driver, 42 MPG)
2005 Suzuki Boulevard M50 (on-road fun toy)
1994 Jeep Wrangler (off-road fun toy)
Nights camped in 2012: 5
Taranwanderer is offline   Reply With Quote
Old 01-26-2012, 05:45 PM   #52
Roybi 2000 Superquiet Generator
...it seems a little more price competitive than Honda and Yamaha...thoughts?
Its kind of comparing oranges and seedless oranges; the difference is the pits.
From a rough read on the web about these units they seem OK though they do not have a operational history like the Hondas and Yamahas. Whether they are as mechanically sound as Red or Blue we will have to wait until that history develops.
The huge reason they are cheaper is that they cannot be paralleled. Both Honda and Yamaha can be paralleled which allows them to deliver almost 4KW.
Ryobi's own literature does not readily lend itself to comparing these "oranges." On the db ratings, Ryobi seems to use a more realistic power setting, but this makes it more difficult to compare fuel consumption to seedless varieties available.
I may have missed it, but I did not see if the inverter is a PSW or MSW. I am assuming it is using at least a PSW inverter or they would not be retailing for $600.
Other than reliability, these types of gensets are probably OK as long as you are OK not having a parallel option. It still, buyer beware, but I would also be aware that there are other manufacturers that manufacturer similar units, and priced in the same range as the Ryobi, with a longer track record.
Foard County News & Sassy Schoolmarm
with Lady & Chloe (2012 days 22)
TT Killed 6/2011 - Getting used 2012 Unleashed 27 SBU
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 04-02-2012, 02:41 PM   #53
This discussion is very helpful. I think the discussion about "clean power" is not complete. The newer inverter type generators are more efficient, lighter weight and quieter. The need for "clean power" seems to be exaggerated. Most modern electronics incorporated circuits that will operate on a wide range of power. The major problem is more likely due to poor voltage regulation in cheaper generators not waveform distortion. One of the main considerations is that appliances such as the AC often require a much higher amperage at start-up than when running. This should be considered when sizing the generator requirement.
Oh and yes I do have a degree in electrical engineering.
cwray is offline   Reply With Quote
Old 04-02-2012, 09:00 PM   #54
Yeah, I don't disagree with you for the most part. However, I can tell you after 35 years of working with computers in the process control environment, that hardware that was on super clean AC power gave us the fewest problems. They even did better than the systems on some very expensive and well engineered Lieberts and Topaz systems.
Really those inverter systems huge claim to fame is what you said it is...excellent voltage/frequency regulation. Compared to a non-inverter systems frequency can be off, and I have measure my genset as low as 105 volts.
To me the bigger question is whether you can tolerate the noise. If you can, get one of those Champions...they really are OK for a lot of applications.
» Online Users: 574
107 members and 467 guests
12vdzl, Alisa06, AvalancheR-pod, ayotte, Barney1, bcunning, bend302, Bradrustan, brookside, Ca Cardinal, Cafjackracing, capndinghy, Cascade Bob, cat1956, Char_n_Kath, chof16, cleancut39, dahn, dashonthedash, dasimser, davidjb, depo, donn, Dunefam, dunnnc, dware1962, ekildog, Falcon35, fonzie, germainesaint, gljurczyk, Glockfanjohn, Goomph, grhodes50, Hob, iluvlcy, ironj, Itsthetwoofus, Jack67, jeshoffstall, jjdegra, jpetrey, jrat, jrlehr, JTHale13, KyDan, Lcountz, LFugate, Lonewolfcry, luv2fish88, mbrink13, merlin66043, Mickey1, milw156, mn_guy, mtnguy, onequicksportster, openroad, Papa Roo, pchrcane65, pcoutfitter63, PrairieBoy, radurecka, rawlus, rburk015, rcflyer540, realebill, rickthelen, RiverL125, RJHuser, robert elling, Rod Johnson, RonLynnJr, Rugged Brown, RV Guy, RvBill3, SabreMarv, SabreSam, Sahgie, sail2liv, sam222, Scriggs1, sellis1053, sfrye5853, shane1234, Skippkon, snjparham, swannie, Tee, Terier, terrystevens, TheFlagGang5, Timex, tking1866, tomjsas, tonybab, travyp, trudinator, Vasvega, vcarbona, vp22er, VTX Al, Warrior, Waterfowlwarrior, waynes, windrider, Zama
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
