Old 06-10-2013, 11:42 AM   #1
jevanb's Avatar
100gal aux tank 250.00
selling my tank because it will not work with my hitch (superglide) should work with all other hitches because my plate rotates and the handle hits the tank, I installed inspection panels from 7075T6 aluminum and it will be sealed to the tank before selling if required, it also had a AN fitting on the lower to attach a line to the factory filler, the shutoff will be included but not the 2inch double bung as it is on the filler now, their is also a tank capacity hose so no need to open tank to see how much fuel is in, measures 23x24x44....100 gallons ... 250.00 local pick up only.. montrose or the airport in waterford MI... 810-515-4968 evan
ID:	32822   Click image for larger version
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
jevanb is offline
