Old 02-03-2013, 10:22 AM   #101
Originally Posted by david-o View Post
For what it's worth, my awning is 21' long and the part number printed on my gas struts is 3108392.139. Can any of you tell me if you have a similar length awning (overall weight could be a factor) and the same - or a different - part number on your struts?
I learned that Dometic also uses number 3310555.010 gas struts on some power awnings. Maybe that one is stronger? If more of you have the "331" strut then I should probably replace both of my "310s" with "331s".
Without the support poles, using the slot for (Heavy items, lights,sun screen,gutting a deer or moose,ect.) will pull the slotted arms down. I have the same struts & awning as you.If you really want to waste your time put ratchet straps on the ends of your awning and (Crank em down).Use support poles! Youroo!!
youroo is offline
Old 02-03-2013, 12:46 PM   #102
Owner/Operator
RodeoGeorge's Avatar
I installed the awning poles and have a problem. Now, while opening the awning, the gas lift strut on the arm towards the front of the trailer (the end of the awning with the electrical hook up) isn't strong enough to hold up its end of the awning. I have to believe it's because of the additional weight of the pole. Has anyone else had this problem?
I'm thinking it might be a defective strut because the rear arm strut seems to be holding up ok. But before I ask for a warranty replacement strut I thought it was best to check here first.
Appreciate any comments. Thanks.
I have a question, and then a comment.
Have you removed the poles and determined that the awning then works properly?
Perhaps the torsion assembly (spring) on the right head is not the correct number of turns.
RodeoGeorge
RodeoGeorge is offline
Old 06-03-2013, 07:28 AM   #103
I recently purchased a new Silveback 35qb4. It is equipped with the Dometic power awning. Are you planning on making/selling any more of the tie down kits?
bclem is offline
Old 06-03-2013, 07:33 AM   #104
I'm not, I think Turbs might be taking some to the Goshen rally in Aug.
OldCoot is offline
Old 06-03-2013, 08:58 AM   #105
Dave_Monica's Avatar
Old Coot...do you want me to change the title of this thread to SOLD?
Dave
Dave_Monica is offline
Old 06-03-2013, 01:03 PM   #106
Dave
Yes, please. I will make the attaching brackets, but no more pole kits. Folks can pm me for the attaching brackets.
OldCoot is offline
Old 06-03-2013, 01:19 PM   #107
TURBS's Avatar
I'll consider making poles...........
Pm me as well.
TURBS is offline
awning
