Old 10-11-2016, 09:27 AM   #11
Cool Where are the fuses?
Originally Posted by PNWTraveler View Post
You were spot on. There were two fuses blown. The batteries were taken in and load tested. They are not toast. They are fine. Replaced the two fuses, recharged and we were back in business.
Grateful to this community for the quick and thoughtful responses.
Gary and Linda
Thanks for that tread
I have the same problem as you , my converter does not recharge the batteries when the RV is connected to 110Vac
The microwave works , and the AC also , but my batteries are going down.....
Can you tell me where exactly, were you able to located these 2 fuses?
I will check that first
I have a Solera 2011
Thanks in advance
Jeff
Jeff172 is offline   Reply With Quote
Old 10-11-2016, 09:30 AM   #12
Hi to all
Can somebody tell me where i can find these 2 fuses , i have the same problem , and I want to check them.
Tks
Jeff
Old 10-11-2016, 09:37 AM   #13
Unhappy Similar problem , my house batteries do not charge?
I have a similar problem than the initial post,
Even if my RV is plugged in the 110 Vac , my batteries do not charge and are coming down
I have the microwave working and the AC and all of the Outlets working also , but it seems like the converter is off duty and do not provide any recharge current to the house batteries??
I have a Solera 2011 type 24SS
Can somebody tell me where i can find the 2 output fuses of the converter , i will check that first.
Thanks a lot in advance
Jeff
Old 10-11-2016, 09:42 AM   #14
bubbles's Avatar
As said, on or inside the converter.
Old 10-11-2016, 10:06 AM   #15
camaraderie's Avatar
Ditto...on or inside the converter. If you know the make and model # (should be printed on the converter) you can go on line to the mfr. site and get the manual for actual location if you can't find it.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 10-11-2016, 10:42 AM   #16
Originally Posted by Jeff172 View Post
Hi to all
Tks
Jeff
There is a panel cover -- I believe it is under the refrigerator. (If not, then just to the right, at floor level.) -- you need to remove a couple of screws to remove it.
I didn't actually do this. Other family member (son) did it. But I'm pretty sure that's where it is.
Linda
Solera 24R
Washington
2015 31 nights
PNWTraveler is offline   Reply With Quote
Old 10-12-2016, 09:05 PM   #17
2012 Solera
Jeff - Did you check the circuit breakers? (My post #3 above). The fuses blowing is rare; the converter circuit breaker tripping on hook up to shore power is common.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-12-2016, 09:43 PM   #18
Left Coast
Turn off the pedestal breaker when plugg'n in
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 10-12-2016, 11:10 PM   #19
2012 Solera
Good advice, Bob. I do turn off the pedestal breaker when plugging in - still occasionally trip the converter breaker. Don't know why. Suspect some form of capacitor charge surge within the converter.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-12-2016, 11:30 PM   #20
Left Coast
Haven't been into one.....YET!
110v, charging, battery
