Old 08-19-2014, 07:43 AM   #91
Mikegjax's Avatar
Thanks, I will check that out.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-19-2014, 08:10 AM   #92
Loefflerh's Avatar
I think I found my problem - corrosion or whatever the green stuff is in the connector for a trailer. Saw a lot of stuff in the plug , cleaned it out and could not see any lights on last night!
Loefflerh is offline   Reply With Quote
Old 08-20-2014, 08:26 AM   #93
Loefflerh's Avatar
Slow_movin, did you try to clean the trailer connector and did it solve your problem too?
Hans
Old 08-20-2014, 03:08 PM   #94
2018 FR3 30DS
I looked and there's nothing there. This rig is basically brand new so I didn't see anything unusual.
They have made some changes in the location of the sewer connection. My sewer connection is no longer on the left rear but is now under the front slide about midway between the front and rear of the coach.. So, I have no idea as to the location of the power board.
Slow_movin is offline   Reply With Quote
Old 08-20-2014, 03:30 PM   #95
Loefflerh's Avatar
Maybe I described it bad - not where the sewer connection is..
Left rear where your power cable is....then back in there there is another door and behind it you find the low point drain for your water and the waterfilter. To the right of the waterfilter is a big board with fuses and connectors...that's it!
Old 08-23-2014, 08:33 AM   #96
Loefflerh's Avatar
Does anybody know where to get a replacement for
- either one of the rear lights (LED assembly)
- the circuit board itself?
Old 08-24-2014, 02:31 AM   #97
2012 Solera
No idea on the circuit board. On our 2012 Solera "S" the taillights are Bargman 84 series. Available from Amazon.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-24-2014, 07:10 AM   #98
Loefflerh's Avatar
Post #92 - I was wrong it did not solve my problem. I t was not dark enough in my driveway to see that the lights were still on, very dim though.
But then I found the license plate light not working - bulb was burned out, and guess what: replaced the bulb - my dim right taillights turned off.
Isn't that strange??? And I could replicate it: bulb out - taillights on, bulb in - off!
Old 08-30-2014, 06:10 PM   #99
Help!
Ok I now have clearance and running light problems. I have a 2012 Solera MB24 that I am setting up a toad, and when I did my first check of the lights everything was ok. After I made up my Solera to my toad cable the running light on the Solera stopped working. So I’ve been reading about this tail light harness and module circuit board panel. Does anyone know where it is located on a MB 24? And is there any fix for the DIY’er?
pinkstonj is offline   Reply With Quote
Old 08-30-2014, 08:39 PM   #100
Mikegjax's Avatar
I don,t know where the board is, but I believe you must run a harness with a blocking diode to prevent your toads elec. system from burning out you LED circuit board. Others may have more concrete info.
2014 Solera 24R
USN Retired
